![]() Join Date: Aug 2006
I need a measurment PLEASE!!!!!
Well I don't have a bed and I am dying to know if i am centered at dump height for the rear axel. Can someone measure from the cab to the center of the rear fleetside wheel well. I know it is a big thing to ask but i don't have a bed yet and would like to know. I don't think i will have the money to buy the bed for about 1 month or so. Or you could measure front he door to center of the wheel well. Doesn't matter. I REALLY appreciate it! Also about how close to the cab does the bed sit? Thanks alot!
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
its all about the +6 inches
Re: I need a measurment PLEASE!!!!!
short wheel base?
long wheel base? Longhorn/one ton wheel base? |
1/2 ton short fleet is the goal, correct?
Thanks Jimmy! Yes that is correct. 1/2 ton SWB with a fleetside bed. Thanks alot!
Josh
anyone?
A guy with a truck
I get about 42" from the front of the bedside to the center of the wheelwell arch. There is an approx. 5/8" gap between the front bed panel and the rear of the cab. The bedside follows the contour of the cab around the side about 1" further forward than the front panel. So, from the flat area of the back of your cab to axle CL should be about 41 3/8".
I would personally wait until you have the bedsides in place to set it permanently though. I just got done setting this on my Blazer and foud that it can be very subjective; i.e. what looked centered to me looked too far forward to my buddy and vice-versa. -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Thank you SO MUCH GringoLoco!!
![]() ![]() Josh
#8 | |
A guy with a truck
-Chris
