Old 01-03-2007, 05:30 PM   #1
72slam
72slam's Avatar
identifying a four speed trans.
Can some one help me identify this tranny. I thought it was a muncie but now I don't know. It has a 10 bolt side plate and an emblem that looks like an N and a P together in the casting. Thanks
72slam is offline   Reply With Quote
Old 01-03-2007, 05:49 PM   #2
fast_dev
fast_dev's Avatar
Re: identifying a four speed trans.
not a muncie, i would say a new process 4 speed. possibly the overdrive one. they work nice im told. Dev.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 01-03-2007, 05:56 PM   #3
72slam
72slam's Avatar
fast_dev,
I bought this about 10 years ago from a junk yard. They said it came out of a school bus. I had in my truck for years. If there is an overdrive in it I don't know about it. Thanks, I'm going to check on that new process.
Old 01-03-2007, 06:14 PM   #4
shifty
Questionable
shifty's Avatar
Please read this thread:
http://67-72chevytrucks.com/vboard/s...=muncie+tranny
It will have all the info you need.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-03-2007, 06:18 PM   #5
shifty
Questionable
shifty's Avatar
PS - it would help to remove the linkage. The easiest way to tell what it is will be to look at the shape of the side plate, count the number of bolts and compare to the PDF link given in that thread: http://go.mrgasket.com/pdf/trans_id.pdf
Looks like a T10, but which one is not clear. You will need to inspect the plate to know for sure.
Old 01-03-2007, 07:48 PM   #6
Green Machine
Green Machine's Avatar
Pretty sure that is an overdrive unit. It would be the New Process NP 440, or MY6, basicly an A833 Chrysler with overdrive. The front shift linkage is reversed. The OD trannys shift into what would be fourth on a normal tranny (direct) for third gear and then shift into "normal" 3rd position for 4th or overdrive. Easy way to tell is to turn the front shift linkage counter-clockwise to shift it and spin the front shaft. If the rear shaft turns faster than the front it is an overdrive unit. If the rear turns slower than the front it is not an overdrive unit. Hope that helps.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-03-2007, 08:34 PM   #7
69_hafton
Sleep-Deprived
69_hafton's Avatar
You'll need one of these (1. for manual clutch) (2. for hydraullic clutch):
1971 K/10 Long Fleetside
350/350 - 6" Lift
1969 C/10 SWB 292 - Sold It
69_hafton is offline   Reply With Quote
Old 01-03-2007, 08:49 PM   #8
69_hafton
Sleep-Deprived
69_hafton's Avatar
Here's a couple more pics I stole Other than a few extra bolt holes here and there, and an extra large shift platform/bracket, the exterior looks exactly like an a-833. I don't know if a regular 4 speed was available from New Process for Chevrolet?
350/350 - 6" Lift
Old 01-03-2007, 10:58 PM   #9
72slam
72slam's Avatar
Thank you everyone for the info. 69 hafton, I have a bell housing like pic 1. I didn't know they made a housing for hydraulic clutches. I plan on buying a kit that bolts to the housing to change to a hydraulic setup.
green machine, thanks for the info. I was reading an article about the upside down linkage bracket, which mine is like. I'm not sure I fully understand the shift pattern. Are you saying go from 1st to 2nd to 4th and then 3rd.? Thanks
Old 01-04-2007, 02:02 PM   #10
69_hafton
Sleep-Deprived
69_hafton's Avatar
The shift pattern is the same as any four speed. I believe what Green Machine is getting at is internally the 3rd & 4th gears are reversed from a normal four speed on the mainshaft (?). The front shift lever on the side cover is the 3rd & 4th lever and is inverted because of this from a normal 4 speed (like yours is). Second pic is of a normal non-OD a833 from a Chrysler vehicle.
350/350 - 6" Lift
