01-03-2007, 08:17 PM | #1 |
Who's got steelies?
67-68 parking brake adustment?
What is the adjustment procedure for the 67-68 hand lever style parking brake? Seems like it should be different than the 69-72 foot lever, but I'm not sure. Any ideas?????
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
01-04-2007, 12:11 AM | #2 |
Re: 67-68 parking brake adustment?
The adjustment is at the end of the front cable - down by the transmission crossmember.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
01-04-2007, 12:17 AM | #3 |
The Older Generation
Here is the procedure as stated in the service manual:
1. Jack up both rear wheels. 2. Apply parking brake 4 notches from fully released position. 3. Loosen equalizer check nut (lock nut on the end of the cable) and tighten the adjusting nut until a moderate drag is felt when the rear wheels are rotated. 4. Tighten the check nut (lock nut) securely. 5. Fully release parking brake and rotate the rear wheels. No drag should be present. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-04-2007 at 12:18 AM. |
01-04-2007, 01:07 AM | #4 | |
01-04-2007, 01:12 AM | #5 | |
LockDoc
01-04-2007, 06:54 PM | #6 |
Who's got steelies?
Thanks LockDoc!!!!! That was just what I was looking for.
Getting the parking brakes working will totally complete the brake rebuild on my hybrid 67/70 .
