Front Bag/Tire ?
I am going to be bagging the front of my 81 C10 this weekend and was wondering if my tires will clear the fender lips, I am running 255/60-15 on a 15x8 w 4" of BS. Scared that it is gonna hit the fender lip.
Any help would be greatly Apreciated |
Happy to be here
![]() Join Date: Mar 2000
Re: Front Bag/Tire ?
That tire is 29.9" tall and 12.4" wide. With only 4" of backspace it sounds like your headed for the fender lip. What spindles do you have?
If you also have dropped spindles, when aired out it will most likely rub the outer fender lip @ close to full lock on the steering. You'd be better w/4.5 ~ 5" back spacing. The prob then is w/only a 15" wheel, you'll need to trim the lower a-arm lip further back because it will contact the wheel much sooner than full lock.
Accoring to your specs i don't forsee any problems. You have to remember that the lower you go the more your wheel & tires lean into the truck. I know it may look like it will hit, but it won't (well mine didn't). When you are aired out (assuming that you remove your lower control arm bump stop mounts) your inner fenders will most likely sit on the tires (assuming you keep them in) So in order to drive the truck you need to raise it somewhat anyway which should also be more than enough clearance to turn fully. But as Scoti you will prolly need to grind your arms down to clear the wheel lip.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough! ![]() |
DJM 3" drop spindles
Happy to be here
I asume you have already trimmed your A-arms?
never had a problem with rubbing only between the caliper and the wheel, the tires are only 27" tall though contrary to your earlier post.
Never had to never rubbed, only rubbing was between the caliper and the wheel. The tire is only
27" tall with a 10.2" section width not 29.9" tall and 12.4" wide. Last edited by Col Clank; 01-04-2007 at 11:08 AM. |
nope wont work unless u get enough lift i have 255/60 tires on old skool moons 8 inch wide wheels and i put 3 inch spindles just for drop and i couldnt even back out of my shop and try to turn without eatin the lip all up so i ended up puttin 235/70s on the frt and it cleared but didnt clear the inner fender
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
been driving it for several months with 5" drop on front 3" spindles and 2" drop springs without any problems, inner fenderwells are out of the truck.
here are some of my new parts minus air line
I guess we will find out this weekend, I will post pics up of how it turns out
#13 |
i see that you got the front bagged now. looks good! so was there any rubbing the fender at all? What are your plans for the rear?
#14 |
Only when fully laid out it rubbes on the fender innerstructure. gonna cut that out so no biggie. For the back I am saving up to do a 4 link and coilovers with a super C so that I can run 33x21.5-15 micky thompson sportsmans on 15x15 convo pro's. Just taking a long time to save up the money to do it all at once, front just looks that good really low.
#15 | |
Until Seventy Times Seven
I saw the pics you posted in the other thread and it looks good. ![]() Good job. ![]()
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#16 |
will post an aired up pic later today, yes it did give me the lower ride height that
I wanted. When It is layed out I have about an inch between the tire and fender lip. |
