Old 01-04-2007, 07:55 AM   #1
BigFishBobby
Removing Dash Pad Cover
I am pretty sure I got one of these el cheapo plastic dash pad covers over my dash pad on my 69 C10. I want to take it off and replace, but cannot find any screws. I take it that it is glued on? Also, where are the screws to take off the actual dash pad? I figure they are under the dash pad, but I don't want to destroy it looking for the screws. Thanks.
BigFishBobby is offline   Reply With Quote
Old 01-04-2007, 08:00 AM   #2
ostncoln
ostncoln's Avatar
Re: Removing Dash Pad Cover
yeah they are underneath the pad. studs go through the dash. you get to the nuts from backside under the dash, i cant remember how many though
ostncoln is offline   Reply With Quote
Old 01-04-2007, 08:05 AM   #3
jamon8
jamon8's Avatar
spend all day reaching under dash or take the glove box liner and the cluster out and presto you will get to the speed nuts that hold her together
jamon8 is offline   Reply With Quote
Old 01-04-2007, 08:24 AM   #4
BigFishBobby
Thanks guys. Looks like there is no easy way out of this one. I think I will order the new dash pad and see how many studs, and where they are positioned before attempting anything.
Old 01-04-2007, 10:12 AM   #5
72armyswbtruck
72armyswbtruck's Avatar
That's a good plan
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-04-2007, 04:49 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'll really hate the job if you have A/C.
Honestly, when I did mine, none of the nuts went on, just the screws, and no one would ever know either.
Old 01-04-2007, 05:50 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Be careful tightening the nuts back down.If you overtighten one it will cause the pad to not lay flat.I found that a 1/4 in socket set with extra extensions and swivels helped a lot.Going back I put a small piece of double sided sticky tape inside the socket to help hold the nut.(Rub it with a bit of dust or lint so it sticks to the socket and only holds the nut).I don't have AC but I can tell you it would be a pain to get to with it since it is without.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-05-2007, 11:22 AM   #8
raoul.duke
Sandwich: Club
raoul.duke's Avatar
It may not seem like it, but you can save time and maybe a broken or cut up wrist if you pull out your dash bezel (including headlight switch), center a/c vent and radio, and your glovebox.......
raoul.duke is offline   Reply With Quote
Old 01-05-2007, 11:24 AM   #9
Joe67
67 is sold
I was suprised to see how that dash pad was attached on my 67 - that thing wasn't going anywhere
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
