Drip rail removal
Has anybody done a write up or FAQ on shaving the drip rail (67-72 pickups)?
I did a search, and found lots of references, but no actual in depth information. Before i venture down this road, I'd like to be prepared for what i find. do people just cut it off flush, and dress up the seam, or do you cut it out and have to fill a gap where it once was? if there is a gap, how big is it, is is small enough (like rokcrln talks about) to tack in some tig wire? Input is greatly appreciated.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 01-04-2007 at 04:33 PM. |
![]() Join Date: Aug 2006
Re: Drip rail removal
I am getting to venture down that road pretty soon also. I was at a car show about a month or so ago and i talked to a guy who did all the work himself. What he told me was that he would cut off about 4-5" or so and then he tacked it up pretty well. Then go another 4-5" and repeat the process. I think you were asking on what to expect and sorry i don't know yet but i still thought i would share the information that i found. Good luck and please keep me posted on your findings!
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
I for one would never remove my drip rail. But living in Oregon, it serves a much needed purpose
Cowboy Fan for Life!!!!!!
I'm getting ready to shave the rail on my truck and I am planning on doing two things; 1.) Drag an old cab up to the garage and practice the first foot or so of the welding and 2.) I am only going to cut off about 2" at a time to ensure that I don't get any "spread" between the two panels. I plan on taking a lot of pics and I'll post them so everyone can see what not to do...
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS Last edited by Bamm; 01-04-2007 at 02:25 PM. Reason: eye sumtymes don't spell two gud... :) |
i saw porterbuilt i think, did one where he used 5/8" solid rod i think thats how i'm gonna do mine.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
#6 | |
I figure, if i have to cut it off to repair/replace it, I may as well save myself some time and just shave it all together. Maybe rokcrln will chime in, as i believe he did this on project lemondrop ![]()
What would be the consequence of shaving the drip rail except for making your wipers work more? I mean I'm scanning the parking lot now and I don't see a single vehicle, car or truck, with a drip rail. Some of the guys that have done this, chime in, let us know if it had any bad consequences..... Loopie
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
soon to be bagged64sub
Ive done my drivers side and it sucked so bad I havent got around to doing the rest. Its just a tidious process but it does look really good. I wouldn't do it again unless they were in really bad shape (which mine were).
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
So you're saying it sucks that it's so much work but it looks cool? Any pics of where you are at with it now? Is there much of a difference when it rains?
67 chevy SWB Fleetside
I had a friend who does body work and painting for a living do mine about two weeks ago. I helped some. It was fairly easy. All in all it took about 10 hours.
We removed the drip rail that is spot welded on above the doors first by drilling the spot welds. Then proceeded as described in previous posts about 8 inches at a time. There is no real gap as the cab roof and window frames just touch. We used a MIG placing a dot about every 1/2 inch and then going back later to fill inbetween, always using small placed weld dots. Stacey David did a nice video of this on Copperhead on Trucks TV. I haven't checked but wondered if a past episode could be ordered on DVD. I follow his technique from memory. When done we ground the welds smoother and then used a little bit of fiberglass filler to really make it smooth. This does leave a little bit of an overhang above the winshield glass, and the gap around the door is now 1 material thickness greater as we took off the afore mentioned spot welded piece. We just painted the truck and it is being wet sanded and buffed this week. I will post some finished pictures next week. BTW, The lemondrop project build post does have one nice in process photo showing the area just above the "a" pillar welded up. |
Stacey David has a new show coming out on espn2 on 3-31-07 called Gearz.
On his web site staceydavid.com it tells all about it, they also have the dvd's for sale from the trucks episodes, it says that they are full length from start to finish on all of the projects from the show not just the 30 min. they showed on TV, might be of some use for the drip rail shaving tech you were talking about. |
![]() this is what I want my drip rails to look like. Last edited by Schralper; 01-05-2007 at 12:25 PM. |
#13 |
I cut mine off with a cutoff wheel leaving the bottom part of the driprail in place to keep the gap the same and I used Dynaglass over that.
#14 |
Hey bagged69c10 - How long have you had your rails shaved? Any negatives?...............Jerry
#15 |
I think about a year. It doesn't bother me but I dont drive it in the rain much.
#16 |
![]() Join Date: Jun 2002
Be careful and plan it well before you start... I've bought 2 different project trucks cheap for parts and shaving the drip rails is where they both jumped the shark. This isn't the same as replacing rockers and cab corners... It does look great when it is finished though.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#17 |
THE VILLIAGE IDIOT
uh what about the rain..but i guess with a really nice truck,,i wouldnt drive it in the rain that much...could you make a chanel like on the newer cars and trucks that would act like a drip rail
honestly honey,,i have no idea how that truck got here. ![]() |
#18 |
Junior Member
![]() Join Date: Dec 2005
Take a look at BP 68's thread from yesterday evening at about 6:28... He showed some nice pics of his project and really covered the drip rail removal well. It's not easy, but the effort is well worth it and the finished product looks sweet!!.
#19 |
You could check this thread also-
http://67-72chevytrucks.com/vboard/s...d.php?t=193559 |
#20 | |
#21 |
i like the way rokcrln did project lemon drop he explains a little on what he did and used.
#22 |
if you don't shave them and you really wanted to do it you will regret it in the long run. That's my theory
#23 |
In Memoriam...
As I understand, the exterior rail keeps water from dumping on you when you open the door. Newer vehicles doors and seals are designed differently, to internally channel the water away. I don't know how well this works in practice, but that is the theory.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." Last edited by FarmTruk; 01-06-2007 at 12:41 AM. |
#24 | |
Thanks Farmtruk, it'll give me an excuse to park it in the garage when it's raining..... ![]()
#25 |
![]() Join Date: Mar 2004
after looking through links that lead to links that lead to links i found some pictures: http://www.imagestation.com/album/?id=3130330093
i'm not particularly fond of the method pictured as it looks hodge podge in my opinion but at least it's something other than "me too" reply's. ondrew |
