Old 01-04-2007, 02:39 PM   #1
cameeks
Long Fleet Club
cameeks's Avatar
Exclamation Need Ideas With Gas Tank
I'm wanting to put a tank under the bed and all the links I have found were around 2 years old. I'm looking for people who have already relocated their tank with any oem tank so I can get some pics and tips on install. I'm wanting to do something with an external fuel pump. Also any new ideas on a filler location.
cameeks is offline   Reply With Quote
Old 01-04-2007, 02:52 PM   #2
HuggerCST
HuggerCST's Avatar
Re: Need Ideas With Gas Tank
I'm doing mine now, using a American Classic tank kit, and hiding the filler behind the tail light. Search "Custom fuel filler", and you'll get a few ideas. There is also a good post in FAQ.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 01-04-2007, 04:57 PM   #3
cameeks
Long Fleet Club
cameeks's Avatar
I looked in the faq and got a few ideas. There was a mention about a 70 mustang tank has anyone done this?
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
Old 01-04-2007, 05:27 PM   #4
zacut
67 chevy SWB Fleetside
I am in the same process but didn't like the prices of some of the aftermarket tanks. I know a tank manufacturer and have done some consulting work for them in the past, so I sent them a sketch a couple of days ago with dimensions to see what they could do. So far it looks promising. I will let you know how it proceeds. I hope to have quotes back from them this week. It should be bolt on.
I have wood bed floor and am installing a flip up stainless steel access cover in the bed with the cap on the tank below that.
zacut is offline   Reply With Quote
Old 01-04-2007, 05:46 PM   #5
cameeks
Long Fleet Club
cameeks's Avatar
On the filler I was thinking of getting a door assembely off of a truck at the junk yard and cutting a round opening in the bed close to the tailgate and welding the cut out part to the top of the door so it still looks almost like it wasnt there. But not 100% sure yet on that.
Chris Meeks
Old 01-04-2007, 05:54 PM   #6
68speedalert
Semi-Senior Member
68speedalert's Avatar
After putting a plastic tank in numberone son's (72afr), I would steer clear. Get a steel one.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 01-04-2007, 07:42 PM   #7
mnunn454
mnunn454's Avatar
I'll be starting my own tank relocation in a month or so. So once you guys get all the problems all ironed out, it'll be smooth sailing for me.
So far, the least expensive 21 gallon steel relocation kit I've seen is LMCtruck. Their Fall 2006 catalogue (Page 108) says the whole kit incl tank, sending unit, straps, is $199 plus about $30 for shipping from Kansas to RI. Checked GMC Paul's website and the kit's listed for about $30 more, but I'll call them before buying to offer them 1st crack.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 01-04-2007, 09:11 PM   #8
HuggerCST
HuggerCST's Avatar
So far, the least expensive 21 gallon steel relocation kit I've seen is LMCtruck. Their Fall 2996 catalogue (Page 108) says the whole kit incl tank, sending unit, straps, is $199 plus about $30 for shipping from Kansas to RI. Checked GMC Paul's website and the kit's listed for about $30 more, but I'll call them before buying to offer them 1st crack.
Check with Tim Christian too. One problem that I have just found with putting one in a short fleet with a WOOD floor- The wood is thicker than the steel floor, and has bolts and nuts protruding underneath to boot, giving less clearance on top of the tank. It looks as though I'll have to use spacers between my frame and tank to lower it enough to clear the bottom of the wood floor.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-05-2007, 04:56 AM   #9
Mudder
Mudder's Avatar
Here's an idea............ Go find a 2Wheel drive Blazer and tell the folks you'd really like to check out the gas tank. Tell them why. I bet they will let you check it out. Take a tape measure. I relocated my tank back in the early 90's before the computer was invented. laying under the wifes Blazer I got the idea of using a Blazer tank on my 67 4x4. Went to the junk yard and came home with all the cross members, tank, skid plate, fill tube and the straps for about 60 bucks. Looking at a 4x4 blazer will also work. Check out the distance from the top of the tank to the floor pan. See how much it hangs down under the frame. The newer frames and the older frames are not that much different..................
Mudder is offline   Reply With Quote
Old 01-05-2007, 11:30 AM   #10
cameeks
Long Fleet Club
cameeks's Avatar
Mudder
What year range should I stay in when looking. I'm going to try it like you did first befor I save up all that cash for a new kit. I'm kind of strapped for cash but want to get this done.
Chris Meeks
Old 01-05-2007, 01:09 PM   #11
Brad
Out of the carpool lane.
Brad's Avatar
I used a 73 Suburban gas tank. It hangs down a bit more but it also holds 25 gals. I just had to rotate the filler neck on it 90* to come out the side, but one could easily not do that and plumb it through the floor.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-05-2007, 01:14 PM   #12
Mudder
Mudder's Avatar
Good thing to remember is that different years Blazers Burbs had different size tanks. I think that my daughters Blazer had about a 17 gal tank and mine from a 85 Blazer has a 31/33 gal tank. You will need to research the size of tanks for the diffent years. If i's a 2wheel drive truck I would think the smaller tank would be better fit.
Old 01-05-2007, 09:54 PM   #13
cgoodwin
cgoodwin's Avatar
HuggerCST,
where did you find the American Classic tank kit? what was the cost? How many gallons?
cgoodwin is offline   Reply With Quote
Old 01-05-2007, 10:09 PM   #14
msgross
msgross's Avatar
I have a 21 gallon Blazer style poly tank w/sending unit and straps for my SWB. I wish I would have went with a bolt/in SS or aluminum tank now that I am further into my restore. I bought the kit for $225 and will sell for less and ship if you are interested.
msgross is offline   Reply With Quote
Old 01-05-2007, 10:18 PM   #15
cgoodwin
cgoodwin's Avatar
msgross,
what don't you like about the kit? does it hang down to far?
Old 01-05-2007, 10:25 PM   #16
msgross
msgross's Avatar
no, it looks ok (only fabbed it up, nothing installed) but after seeing a buddies SS tank I like how it looks on the truck. truckandcarshop has a steel version for a good price. Here are some pics of mine..
www.picasaweb.google.com/hawkdriver2002 and here is a build pic, mine looks like this but poly...made in the usa too
http://67-72chevytrucks.com/vboard/s...ghlight=filler
Old 01-05-2007, 10:27 PM   #17
I have an a 21 gal tank from a 72 Blazer. I am going to add a fuel door in my bed side. What I have done so far i in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=221437
Old 01-06-2007, 12:01 AM   #18
FarmTruk
In Memoriam...
FarmTruk's Avatar
What ever you do, don't do it like this...
This is not my truck (just wish it was). This was scanned from a magazine. It's called "Sic Trick" and lives in N. Cali. Another board member pointed out just how low this thing sits. Looks like a major insurance claim just waiting to happen. Just my $0.02.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-06-2007, 12:18 AM   #19
67cst
i love summertime
67cst's Avatar
i just took my poly tank out of the 67 and replaced it with an aluminum fuel tank. ill post pics tomorrow for ya, also if anyone is interested in my poly tank id sell it..straps/sending unit everything you need is there.
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 01-06-2007, 11:26 AM   #20
cameeks
Long Fleet Club
cameeks's Avatar
Did you place the door in the bed area or on the outside?
Chris Meeks
Old 01-06-2007, 04:39 PM   #21
I haven't done it yet, but it'll be on the outside of the bed. I hope it will come out as clean as this one did.
Old 01-06-2007, 05:43 PM   #22
[ol'Blue]
[ol'Blue]'s Avatar
thats clean, i have my poly tank filled from inside the bed.... gonna sell soon. I got a Jaz fuel cell for xmas.
[ol'Blue] is offline   Reply With Quote
Old 01-06-2007, 09:25 PM   #23
cgoodwin
cgoodwin's Avatar
ol blue,
any extra info you can give on a jaz fuel cell?
Old 01-06-2007, 10:31 PM   #24
slt0066
Id recomend spending the extra money on an aluminum or stainless tank that mounts flush with the frame rails on the top side. Im in the process of doing this right now with a new steel repop blazer tank supposed to be a conversion kit. but they dont mention that you have to cut the crossbrace under the bed all the way across be cause the tank sticks above the frame about 2 inches. and the filler points directly were the bolt is supposed to go through the bed to frame. if you want more info or pics on my install let me know dont want butt in
slt0066 is offline   Reply With Quote
Old 01-06-2007, 11:24 PM   #25
HuggerCST
HuggerCST's Avatar
Originally Posted by cgoodwin View Post
HuggerCST,
I got the 20 gallon kit(part # GTN-K01) that is $205. Here is a link- http://www.americanclassic.com/asp/d...ype=to&exyear=
Wynne
Build thread
53 Chevy shortbed
69 Camaro
