01-04-2007, 04:35 PM | #1 |
Neutral Saftey Switch
can anyone twll me what wires go where because with my painless kit i have 2 purpal wires that already have the tips on it but i need to know where them 2 go and also i assume the 3rd one is for my reverse lights?
01-04-2007, 05:09 PM | #2 |
Re: Neutral Saftey Switch
If the painless kit uses the same color code as GM, then the purple wires connect to the neutral switch. I can't remember what color the reverse light wire is....
1997 GMC Sierra Ext 1965 Mustang |
01-04-2007, 05:20 PM | #3 |
The Older Generation
Check this thread out. After the images load (it may take a while) scroll down to the second image. Right in the middle you will see the backup/neutral safety switch. It has two purple and a couple of green wires. Trace them out. http://67-72chevytrucks.com/vboard/s...d.php?t=185665 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-04-2007 at 05:20 PM. |
01-04-2007, 05:20 PM | #4 |
well im tryig to figure out where the 2 purple wires plug in on these prongs i have the colors
01-04-2007, 05:39 PM | #5 |
take a meter and the 2terminals that have continuity when the shift lever is in park and neutral are where the purple wires go// the purple from the ign switch goes to the left
