Old 01-04-2007, 07:31 PM   #1
TraderJon
TraderJon's Avatar
header & motor mount pics
Hopes this helps someone, I used the tubular motor mounts from Brothers & flotech headers for the bbc swap,they fit good,the driver side has about 1/4" clearance on front header tube & the pass side you could throw a full grown house cat thru & not touch a thing.
Flowtech#31530 ceramic coated,$229.99 from Autozone
Mounts,,anchor part#2267 from O'rielly's auto parts $8.00 each
tubular stands from Brothers #I forget?
They do hang down below the frame about an 1.5" though,may have to go to a taller tire on my truck,it's lowered 3&5 with 255/50/17 nitto's.
Jon
TraderJon is offline   Reply With Quote
Old 01-04-2007, 07:47 PM   #2
Mongo
YES_____NO
Mongo's Avatar
Re: header & motor mount pics
LOL now thats funny
, Good pics and info..
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 01-04-2007, 08:11 PM   #3
TraderJon
TraderJon's Avatar
Thanks Mongo
I thought there were a few us on here doing the sbc to bbc swap ,so i threw that tidbit out there,now if i can figure out the power steering brackets we'll be cruising again in a couple weeks.
Jon
Old 01-04-2007, 08:30 PM   #4
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
How hard were the tubular mounts to install?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 01-04-2007, 08:40 PM   #5
TraderJon
TraderJon's Avatar
Didnt have to drill any holes,bolted right in,I shoulda mentioned it's a 72 frame,with 67 sheetmetal, I think the original 67 frames are not carved out at the motor mount area,there straight & will interfere with the stand mounts.
Also learned the hard way,leave all the bolts loose till you get the trans mount pad stabbed in the hole,gives you some wiggle.
Jon
Old 01-04-2007, 08:45 PM   #6
jkade
jkade's Avatar
I appreciate you sharing this, I bought a set of flowtechs from summit for a 72 big block truck to go in my blazer. Now that you said they hang below the frame 1.5" I think I will need to get some diffrent ones.
jkade is offline   Reply With Quote
Old 01-04-2007, 08:50 PM   #7
TraderJon
TraderJon's Avatar
Yeah they hang down a lil further than the sbc did,,I'll try to get a side view pic for you,may not be to accurate ,it's still up on jackstands.
Jon
Old 01-04-2007, 08:50 PM   #8
mkhutch
Throbbing Member
I have a 67 doing the BBC swap in. Which holes did you use to mount the towers in? Also what is the white stuff under the upper tower mount?
mkhutch is offline   Reply With Quote
Old 01-04-2007, 09:01 PM   #9
TraderJon
TraderJon's Avatar
I used the front v8 holes ,,I marked the old sbc stands before I pulled em with a paint stick for reference ,I get the crs stuff sometimes..
Jon
Old 01-04-2007, 09:07 PM   #10
TraderJon
TraderJon's Avatar
JKade
Heres a pic,It may even hang lower than 1.5",,I always go by the collector height,usually thats the first part to drag the dirt?
Now that i think about it,,thats a 3' collector.
Jon
Old 01-05-2007, 03:29 PM   #11
Slammed70
Slammed70's Avatar
Could you please post that PN for the tubular mounts?
I flipped through my brothers catalog 4 times and didnt see anything.
Thanks,
Mitch
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 01-05-2007, 03:34 PM   #12
Slammed70
Slammed70's Avatar
Nevermind, here they are.....
http://brothersonlinestore.com/prodi...number=ESM6372
These arent in the catalog for some reason.
