01-04-2007, 08:47 PM | #1 |
Need headers for a bbc that don't hang below the frame!!!!
What are you guys running that don't hang below the frame? I bought the flowtechs but I just found out they hang down over a inch. Thanks
01-04-2007, 09:52 PM | #2 |
Re: Need headers for a bbc that don't hang below the frame!!!!
http://store.summitracing.com/partde...5&autoview=sku
Reckon these will fit? |
01-04-2007, 10:40 PM | #3 |
I just put the Hooker ceramic coated headers on mine and had to grind out some of the transmission cross member...they are that high
01-05-2007, 01:50 AM | #4 |
The only ones I found for a Big Block was the Sanderson headers. For a small block I have heard alot of people using the chevelle shorty's.
01-05-2007, 02:10 AM | #5 |
Turbo Guy
Heddman bbc shorty's for a mid 70's monte carlo. If you want I can find the part #
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles. 1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit! Things I've broken so far: 12 bolt diff saginaw 4 spd many, many pieces Aluminum case Super t-10 4 spd |
01-05-2007, 09:16 AM | #6 |
The only thing that worries me about the hedmans is the thermal coating. I wonder how well that will hold up compared to ceramic coating?
01-05-2007, 11:07 AM | #7 |
02-16-2007, 07:53 PM | #8 |
How did the Patriot Clippster Headers work out??? I have seen the small block clippsters on a 73-87 before. They seemed to fit real good.
02-16-2007, 08:09 PM | #9 |
Straight jacket required
Yup, what he said!!!
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." |
02-16-2007, 09:49 PM | #10 | |
I am happy with them. I had to grind a little on the drivers side motor mount and a little on the passenger frame rail but they are heavy made and look great. |
02-16-2007, 10:52 PM | #11 |
-Praise the Lowered-
CLICK HERE to see some headers I installed some time back using Hedman's BBC shorty from a late 60's early 70's Chevelle/Malibu.
As Mentioned above, I also had to slightly trim the top of my passenger side frame rail (about 1/8" to 1/4"). I Just used a grinder. Though the overall exhaust system does hang below the frame rails, the actual headers/collectors do not. If I didn't have other things in the way, I could have routed the exhaust completely w/ in the rails. Hope this helps....
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) |
02-16-2007, 11:04 PM | #12 |
I have Doug Thorley Tri Y Headers on my 402 and they fit pretty well with no major issues.
02-17-2007, 12:12 AM | #13 |
The Engine Whisperer
02-23-2007, 03:45 PM | #14 |
Ttt
