Old 08-23-2002, 12:21 AM   #1
worldofme
brakes
I just replaced the power booster and master cylinder in my '77 Blazer and I'm having trouble with bleeding the brakes. I've gotten the rear brakes done just fine but when it comes to the front disc brakes I open the bleeder screw and no fluid comes out even after several pumps on the brake pedal. I'm going to get one of those one person bleed kits to see if I can suck the fluid out but if not, any suggestions? I know there is air still in the lines but I would think that if the rear brakes had fluid going to them then the front brakes should as well.
Any help would be appreciated. Thank you.
worldofme is offline   Reply With Quote
