Old 01-05-2007, 08:34 AM   #1
musiqlova
Door rattle
Does anyone know how to fix "loose" doors? My passenger side door closes good, but has some movement when the door is closed. When I go over bumps, the door rattles and it's quite annoying. Does any know how to fix that?
musiqlova is offline   Reply With Quote
Old 01-05-2007, 10:36 AM   #2
mike3311
mike3311's Avatar
Re: Door rattle
Open the door slightly and lift up on it while looking at the hinges. Do you see any play in the hinges / pins. There should be virtually no movement between the two halves of each hinge. If there is, you could replace the pins and bushings and that'll probably fix it. Another test for loose pins and bad alignment is to inspect the door jamb and floor plate for chipped paint or rust where the door might be striking the jamb or plate while it closes.
If the alignment checks out, I would look for loose components inside the door. I had a serious rattle coming from my window motor hittng the outside of the door and discovered that onw of the bolts holding the motor had torn through the sheet metal. 2 washers later and that rattle was gone .
Good luck
79 C10 Silverado
mike3311 is offline   Reply With Quote
Old 01-05-2007, 10:43 AM   #3
mike3311
mike3311's Avatar
Re: Door rattle
Also, if you mean that the door has movement in the horizontal when it's closed (IE, it moves when you push and pull on it while closed) you could check the striker pin for wear and replace it as needed. The door and jamb seals could also be replaced if they're old and compressed, that'll help give a tighter fit.
79 C10 Silverado
Old 01-07-2007, 02:11 AM   #4
karl
karl's Avatar
Re: Door rattle
most likley its one of three things. striker, latch or alignment or any combo of these things. i know this is annoying. and aligning doors is a *****. so i think so.
karl is offline   Reply With Quote
Old 01-10-2007, 11:25 PM   #5
HOGDADDY
HOGDADDY's Avatar
Re: Door rattle
Mine used to rattle til I replaced the lower window rubber bump stop located inside bottom of door.
HOGDADDY is offline   Reply With Quote
Old 01-11-2007, 12:10 AM   #6
ureckme
ureckmefixit2@cox.net
Re: Door rattle
Put a piece of hose on the striker.
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 01-11-2007, 07:49 AM   #7
musiqlova
Re: Door rattle
hmmm..... good thought and cheap fix. I'll try that this weekend!
Thanks!
Old 01-15-2007, 06:34 AM   #8
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
Re: Door rattle
I just bought the cheapo plastic sleeve kit at Oreillys to fix my rattling passenger door. The striker bolt had lost its plastic cover.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 01-16-2007, 12:16 AM   #9
ureckme
Re: Door rattle
I have I think black 5/8 heater hose on mine for 3 years and it's still good. No rattles and the door shuts fine.
Matt
74 Chevy Short Bed
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
Old 01-23-2007, 06:45 AM   #10
musiqlova
Re: Door rattle
Matt
I finally got around to doing this. It worked great! I used the heater hose too!
Thanks everyone!
Old 01-23-2007, 10:06 AM   #11
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Door rattle
Replacement strikers are just a few dollars in the HELP! section.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
