01-05-2007, 09:26 AM | #1 |
Where to mount tach?
Anyone have any pictures of where they mounted a tack in their truck? Its not going in the dash or on the dash, so I was thinking of mounting it either on the column or at the bottom of the dash below the cigarette lighter. Anyone mounted one to their column?
01-05-2007, 11:24 AM | #2 |
Parts and more parts
Re: Where to mount tach?
I mounted mine and my son's on the driver's 'A' pillar, by using a screw that was already there for the trim piece. This put's the tach just above the dash on the left hand side and it is just below eye level. I used a piece of "Mill-stock" aluminum and drilled it to have the screw go through it, then I tapered the end that is close to the windshield so that it would follow the contur and hold the bracket solid. The tach is then bolted to the strap and faced out to the driver. The wire for the tach is fed down past the dash at the end of the padding..
01-05-2007, 11:58 AM | #3 |
A pic would be great if you have one.
01-05-2007, 12:15 PM | #4 |
email me @ wilbanks89@cox.net i have a pic u can see
1973 Chevrolet C20 (Under Construction) |
01-05-2007, 12:16 PM | #5 |
01-05-2007, 12:16 PM | #6 |
I mounted mine on my column just ahead of the tilt and the shifter. The wires were run down the top of the column and under the dash with the column. It only covered up the 2 warning lights and maybe a bit of the gas gauge. I used a hose clamp to mount it. Not the prettiest thing to use but it worked. It also puts it in the same area as the other gauges so that it is easily seen while checking the others.
If you mount it under your ash tray it is out of the way to look and you are looking down.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
01-05-2007, 08:00 PM | #7 |
Try these on for size. As you can see, no holes in the dash.
01-05-2007, 08:01 PM | #8 |
One more from the front.
01-05-2007, 08:04 PM | #9 |
needin' money
i know you said not to, but
SWB Stands for Short Wide Bed |
01-05-2007, 10:40 PM | #10 |
Sb 400 club
ahhh shift lights! ah just kidding guys. i got the sunproe 3 inch tach but i tried the hoes clamp and no dice! it interferesas with the tilt function. I will probibly drill the dash and mount it near were peice parts did when i mount it. Iknow drill the dash???? Well mine is a aftermarket pos so it is not really that big of a loss. I would aso sugjest maybe a piller tach with a trans temp and somthing else. munting below the radio i think is foolish cause you have to look down to see it
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
01-05-2007, 11:28 PM | #11 |
Location: vacaville ca, because it as far from indy as i can be
i mounted mine to the column at the closest to the dash with a column shifter, but i set it so that in the d/od position it was straight up and between the fuel and speedo. in p it was way off center and tilted funny.
01-05-2007, 11:39 PM | #12 |
dang its hot
like 82c10, mine is in that position but I used a mirror mount on the windshied and fabbed a mount to the monster tach body. the truck is apart now so I don't have a pic
01-06-2007, 12:53 PM | #13 |
I put mine here...
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
01-06-2007, 08:00 PM | #14 |
7000 #'s of american IRON
I've got a 3" on my column with a hose clamp, in first it blocks the left signal and part of the shift indicator, in drive it just barely lets me see the signal. In park it's about horizontal.
01-07-2007, 08:20 PM | #15 |
Thanks for all your input, I ended up putting it on the upper part of the column that doesn't rotate with the gear selector. I had to take out the tilt lever, but I never need to adjust it anyway and nobody else drives it. I attached some picture of the install. I didn't tuck away the wiring very well but it looks ok. A big hose clamp and a little electrical tape and it doesn't look to bad.
01-07-2007, 08:32 PM | #16 |
Is that a replacement dash face? I don't think it is (as I think i see a washer in that very special spot), but if it is, where did you get it?
tach looks good. |
01-07-2007, 08:37 PM | #17 |
01-08-2007, 09:37 AM | #18 |
01-08-2007, 09:38 PM | #19 | |
mine's all faded, that upper left corner is completely gone, so i'm looking for a new or NOS one..junkyards come up empty, all the sierra classics have the sheetmetal faces that i find. |
08-21-2009, 02:51 PM | #20 | |
08-21-2009, 03:07 PM | #21 |
Here is where I had mine on my 91 burb. I made a panel with some "el cheapo" home depot diamond plate plastic I had laying around. I'll probably get a 5" tach for my 86 when I get closer to finishing it.
08-22-2009, 09:30 AM | #22 |
Still plays with trucks
08-22-2009, 09:38 AM | #23 | |
If you have a bigger than stock cam keep a stock 400 bottom end below 5500 rpm and you will be OK. The short rods are the weak link. With a 5.7" rod or 6.0" rod upgrade it can spin just like any other small block. |
08-22-2009, 10:21 AM | #25 |
Yo! I gave up after being unable to find a functional, asthetically pleasing installation. I had considered ALL these possibilities, but I think I'll repeat what I did in my '76 Camaro,...replace the HUGE gas gauge with a tach, and install a small gas gauge in the clock option position with the small gauges.
Sure would like to have it displayed in the windshield glass just in front of the steering wheel. Hummmmmm,... Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
