i deserve a trophy for most crap ever found inside a fender
i had noticed a little rust creeping through the front fender corner on the passenger side of my 72, i didnt really care since i was swapping to a 67 front clip with new fenders etc nor did i wonder why it was rusting there and not on the drivers side which was perfect. well ive started the swap this week and check out what i found inside that fender corner
the following was found.. 1 wrench 1 rag 1 screwdriver 1 battery terminal 1 nose to a tube of rtv sealant 1 razor blade 1 gasket of something 1 rubbet grommet fo somesorts assorted coins 5 lbs of dirt ![]() ![]() ![]() ![]() |
and no i dont think its possible for all of this to have just accumulated there, when i checked the drivers side there was nothing but maybe a rock or two and a pinch of dirt. its almost as if some previous owner saw the rust and though dumping 5lbs of cat litter or gravel down into the fender corner would absorb the moisture and keep it from rusting, boy was he wrong. the rest of the fender and clip on my 72 is pretty rust free as most CA trucks are. do you think the fender is trashed? it would need a new corner welded at the bottom but the rest of it has no rust
heres how i look right now
ps check the classifieds soon i have a good 72 hood and core support as well as the rest of the front clip for sale |
fender junk
Rats, all I found in mine was a quart of tranny fluid and a funnel.
at least you have an actual pocket in existence on that fender to have bene able to accumulate all that, around here the pockets dont exist and all the crap has long since fell through, even all that would have, wrench and all, lots of rain and high humidity wet air+ dirt and mud and salt and snow and ice = major rot issues on all sheetmetal objects
hehe |
Recovering Truck Driver
randy's right, i've looked at probably 20 trucks in junkyards in my area and all of them have the cup on the right front fender totally rotted away, the only one that isn't gone is the one on Dad's 67, and it's bashed beyond repair.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
chevelito
oooh... if they are craftsman tools, maybe you can turn them in to get new tools and then hock or use those.
just a though, jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
My other Love
I once found dead pack rat in a 68 dodge yikes!
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Hey Blake, did you decide what you are going to do with the extra 67-68 clip? Let me know. I'd be interested, and local, no shipping
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
#10 | |
if your interested in the 72 clip im going to try get rid of it. $125 for everything. inner wells, hood, hood springs and latch, core support, outter grille, aftermarket inner grille, bumper, 2 fenders one is good the other is obviously need a whole new corner to it lol. and all the the little bits a pieces that hold it together |
Just carefully remove the artifacts and preserve them. Ya never know, they could have come from some long lost ancient civilization from 30 yrs. ago, lol. I think the fender is fixable. I've welded up worse, that is, if the rest of its in good shape. I hate seeing original panels getting trashed just because of a few holes. They be getting rarer and rarer.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
OK, I knew you were debating between a few options on the early sheetmetal. So the extra 68 fenders are pretty bad? Hows the hood?
#13 |
Slowly getting CRSS...
i found an old rubber boot some garden gloves and an ice pick in the door of my truck
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
#14 | |
the hood had a quarter sized hole cut into it for an antenna i guess. has a couple of small dimples in it otherwise straight and rust free. i just figured that the money spent to repair the hole and small dimples would be better spent just buying a new cowl hood. if i had a welder and the know how id just patch the hole and do the body work myself, it doesnt look bad but the shops i took it to are telling me it needs $200 of work, ya right... anyways the hood will be going on my truck until i order a cowl hood, so it could be a while till its for sale, but when it is youll see it on this parts forum. |
#15 | |
#16 |
![]() Join Date: May 2002
HEY! That's where my wrench went!!!!!!!!
Stepsides look like real trucks! Smitty ![]() |
#17 |
![]() Join Date: Jul 2000
That is too cool! With all that weight gone, your gas mileage and acceleration will undoubtedly improve.
When I got my 69, it had been driven on farm roads for 20 years. Combine that with a few oil leaks and you get a quarter-inch of greasy dirt stuck to the bottom of the oil pan, trans, cab, bed, and frame. I spent a few hours each weekend for several weeks laying on my back with a putty knife scraping most of it off. Wish I would have weighed it all -- probably 50 pounds easy.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#18 | |
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#19 |
Mine were full of bondo and newspaper.
#20 |
I found 38 silver dollars in a quater panel I was cutting up to sell to a customer when I was in the salvage buisness, they just kept rolling out like I had hit the jack pot on a slot machine!
WAHOOOOOOO!
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air. 68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles 68 anniversary no engine long wheel base 400 auto FOR SALE 68 Chevy fleet side long wheel base complete parts truck. |
#21 |
Used to have a truck
Ive got an real old rusty church key oil can opener thats hanging from a piece of wire thats looped around my drivers side hood bumper. Its old. Its staying there.
No truck :-( |
#22 |
Transcendental Trucker
I found an open Buck 110 knife in mine (blade up! Almost sliced my hand on it..) and an old round jug of oil.
Patrick Sullivan | sullivan@oregoncoast.com Rockaway Beach, Oregon 1972 Chevy Cheyenne C-20 1998 Dodge Dakota 4x4 So, fill to me the parting glass And drink a health whate'er befalls... Then gently rise and softly call Goodnight and joy be to you all! |
#23 |
Pocket Contents
What, you didn't find my gum?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#24 |
its all about the +6 inches
How about the bag of pot I found in my cab corner...well actually, the military police dogs found it there. man did I just barley keep from getting in real deep ca-ca.
#25 |
I think I saw about 14 spark plugs laying on the core support of my truck.(I think it was the core support, it was cold and my brain was froze) also in my glove box, I found a pack of 10 yr. old matches that still light. Hehe. Wait until I get my truck to my house, I'll top all of ya. I bet. lol
Brandon P.S. Longhorn, was the pot yours? or from the dope smokin old man? |
