01-05-2007, 05:25 PM | #1 |
How Many teeth do you have?
Was a 153 tooth or 168 tooth flex plate stock for a 1970 GMC 3/4 ton with a LS9 350.
Glad it's FRIDAY !
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 01-05-2007 at 05:38 PM. |
01-05-2007, 05:34 PM | #2 |
Parts and more parts
Re: How Many teeth do you have?
I believe that it depended on the application of vehicle. My 350 of that era, had the 168 tooth flexplate.
01-05-2007, 05:39 PM | #3 |
I think the 153 tooth were only found on cars that might have had exhaust clearance problems like V8 Monza's, Camaro, Nova, etc. I went with 153 tooth on my V8 powered S10 Blazer for header clearance. It tucks the starter in closer to the block.
01-05-2007, 08:27 PM | #4 |
Most of the 153 toothed flexplates were on cars, but the larger ones could be found everywhere, I f I remember right. The starters for the larger flexplates are the ones with the offset bolt pattern, the smaller were the straight across bolt pattern.
