01-05-2007, 11:01 PM | #1 |
Drum brakes??
I just overhauled my entire braking system, new everything rubber hoses, steel lines, wheel cylinders, master cylinder, spring kits, drums and shoes. My problem is I cant seem to get the shoes to sit properly, they wont close in all the way.At the top their still 2cm away from the main bolt. any ideas why?
01-05-2007, 11:13 PM | #2 |
Dave's not here, man
Re: Drum brakes??
Could you possibly post a pic?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
01-05-2007, 11:18 PM | #3 |
Re: Drum brakes??
01-05-2007, 11:25 PM | #4 |
Re: Drum brakes??
Tried using an existing picture didnt work, wife broke the camera on the weekend
01-06-2007, 12:32 AM | #5 |
In Memoriam...
Re: Drum brakes??
Is the star adjuster all the way in? Are the pads upside down or reversed front to back?
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
01-06-2007, 01:42 AM | #6 |
Re: Drum brakes??
the star adjuster is all the way in and the shoes are on properly.
01-06-2007, 02:05 AM | #7 |
Msgt USAF Ret
Re: Drum brakes??
Here is a thread with pics that may help.
http://67-72chevytrucks.com/vboard/s...ht=brake+shoes
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-06-2007, 04:08 AM | #8 |
Re: Drum brakes??
Stupid Question but is the emergancy brake on?
Did you do just one side at a time?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
01-06-2007, 09:32 AM | #9 |
Re: Drum brakes??
Thanks for all the help guys, The emergency brake is off, but now it doesnt work when applied and it did work b4.the star adjuster is all the way in so the drum will move because the brakes our out at the top still
01-06-2007, 12:33 PM | #10 |
its all about the +6 inches
Re: Drum brakes??
you tried squeezing the shoes in with your hands? There may be fluid in the brake cylinder that needs pushed back in. I find this almost common on a system that's been apart for a while
01-06-2007, 12:58 PM | #11 |
Re: Drum brakes??
Even though the park brake is off, the cables may be partially stuck/frozen.
01-06-2007, 02:34 PM | #12 |
Re: Drum brakes??
that would spread the bottom, not the top
01-06-2007, 05:14 PM | #13 |
Re: Drum brakes??
Assuming you matched up the new shoes with the old ones to make sure you had the right parts (you didn't get them at Auto Zone,did you?),then put on some clean gloves and just squeeze and shake the hell out of them. Sounds light the back edge of the shoe is catching on the ridge in the backing plate.-cougar
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
01-07-2007, 11:34 AM | #14 |
Re: Drum brakes??
THE PROBLEM IS THE STAR WHEEL ADJUSTER CANNOT BE IN ALL THE WAY. yOU TURN THE STARWHEEL OUT TILL THE SHOES JUST TOUCH THE DRUM. tHIS IS WHY THE EBRAKE WONT WORK CAUSE THE TRAVEL OF THE CABLE IS NOT ENOUGH. kEEP IN MIND HOW FAST THE BRAKES GRAB WHILE PRESSING THE BRAKE PEDAL IS BASED ONLY FROM ADJUSTING THE REAR STAR WHEEL ADJUSTER IF YOU HAVE DISK FRONT BRAKE. ALSO CHECK YOUR SPRINGS THAT WRAP AROUND THE ANCHOR PIN AS THEY ALSO PULL THE SHOES TO WHEEL CYLINDER
01-13-2007, 09:06 PM | #15 |
Re: Drum brakes??
Thanks guys for all the help. It ended up being my Emergency brake, the horizontal bar is what was keeping my brakes apart, it must have been pulled with the drums off. ( i was doing new guages as well). again thanks for all the help and im excited to have it back on the road, blue betty
