Old 01-06-2007, 01:25 AM   #1
dave666693
dave666693's Avatar
No spark question
I just started working on a 68' inline 6 250 that has been sitting a year or so. I have spark coming out of the coil but no spark coming out of the distributor cap. The PO looks to have put on a new cap, rotor and points apparently trying to get it started. The funny thing about the spark at the coil is it is only there at the beginning and end of cranking it over. Is that normal? Any thoughts on where to go next? Thanks for any help!
dave666693 is offline   Reply With Quote
Old 01-06-2007, 01:42 AM   #2
kenm78
Broken Down
kenm78's Avatar
Re: No spark question
Im assuming this is points. Did you put the cap, roter, and points in yourself?
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 01-06-2007, 01:52 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Your post is not too clear about the spark but you should get a spark each time the points open with the key on. Anyways here is the cure to your problem courtesy of Shifty.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-06-2007, 01:59 AM   #4
dave666693
dave666693's Avatar
It is points and the PO put them in. I have checked the points gap and cleaned them. I replaced the condensor. I will certainly go to a HEI but I want to get it running 1st to evaluate the engine.
Old 01-06-2007, 02:05 AM   #5
skchevota
skchevota's Avatar
Check to see if it looses voltage to the coil while cranking.
skchevota is offline   Reply With Quote
Old 01-06-2007, 03:14 AM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is the best site I have on points ignition systems.http://abbysenior.com/mechanics/ignition.htm
VetteVet
Old 01-06-2007, 03:16 AM   #7
72armyswbtruck
72armyswbtruck's Avatar
Hope you get here running, I am no help with points
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-06-2007, 10:59 AM   #8
dave666693
dave666693's Avatar
Great link Vette. Lots of good info there.
Old 01-06-2007, 11:08 AM   #9
faribran
faribran is offline   Reply With Quote
