Old 01-06-2007, 11:27 AM   #1
manimal
manimal's Avatar
Rear gear ratio?
How do you check what gears you have without pulling the rear diff cover?
manimal is offline   Reply With Quote
Old 01-06-2007, 12:16 PM   #2
cdowns
cdowns's Avatar
Re: Rear gear ratio?
jack the rear end up put a piece of tape on pass side wheel have in neutral turn driveshaft count the number of revolutions of drive shaft to one revoulation of rear wheel will give you a ball park figure of your ratio
Old 01-06-2007, 12:46 PM   #3
manimal
manimal's Avatar
Well I did that. And the driveshaft turned '5' times to the wheels one turn!! Could this be right? Its a 1/2 ton that originally had a 6 cyl and three on the tree.
Old 01-06-2007, 12:53 PM   #4
Elsie72
Chinook Arch
Elsie72's Avatar
If the rear end doesn't have a posi, if only 1 tire turns with the above test, the spider gears will cause the opposite wheel to turn twice as fast.
Ensure that either both wheels are turning through the whole test, or block one wheel, and devide the result by 2.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
Old 01-06-2007, 01:08 PM   #5
manimal
manimal's Avatar
well I did that(block one wheel) and now I come up with 1 3/4 turn.nobody here to help me with both wheels. Guess I need to pull the diff cover
Old 01-06-2007, 01:13 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
pull the cover off, if you're lucky, the oil is only 20 years old and needing changed. It's possably original oil and only doing 50% of it's job.
Old 01-06-2007, 01:45 PM   #7
msgross
msgross's Avatar
I agree...can always use new gear lube.... there is a post on here that helps you decipher the ring gear numbers.
msgross is offline   Reply With Quote
Old 01-06-2007, 01:48 PM   #8
cdowns
cdowns's Avatar
of the hundreds upon hundreds of rears i've checked in the past 40 years i've never seen one spin the tire at twice the axel ratio
Old 01-06-2007, 01:53 PM   #9
msgross
msgross's Avatar
i've checked out a lot of rears in my time too, i've seen them bounce more than spin ...oh wait, you mean trucks
Old 01-06-2007, 08:59 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Here are the numbers you will be looking for on the ring gear & Pinion when you get the cover off.....
Ratio 2.56:1 - Tooth Combination 41,16
Ratio 2.73:1 - Tooth Combination 41,15
Ratio 3.07:1 - Tooth Combination 43,14
Ratio 3.08:1 - Tooth Combination 40,13
Ratio 3.08:1 - Tooth Combination 37,12
Ratio 3.31:1 - Tooth Combination 43,13
Ratio 3.36:1 - Tooth Combination 37,11
Ratio 3.42:1 - Tooth Combination 41,12
Ratio 3.55:1 - Tooth Combination 39,11
Ratio 3.73:1 - Tooth Combination 41,11
Ratio 4.10:1 - Tooth Combination 41,10
Ratio 4.11:1 - Tooth Combination 37,9
LockDoc
Leon
Old 01-07-2007, 02:03 AM   #11
Rod
You could also assume ratios based on glove box stickers with no listed gear option changes. You just go by standard equipment lists depending on the tranny and engine size. Typically straight 6 came with 3.73 and v8 came with 3.07 on 2wd model in 1/2 ton series in the 67-72 era.
You could also use the code stamped on the axle tube also...hoping it had not been swapped or altered.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-07-2007, 03:17 AM   #12
69TowRig
Regardless the above advice is true, if you hold one wheel and turn the driveshaft the other wheel turns at twice the ratio. This has to do with the fact that the carrier walks the spider gears around the side gear that is stationary from the held axle shaft. Those gears in turn drive the opposite side gear one extra turn for each revolution of the carrier.
It's a fun math problem to do when you are a Mechanical Engineering student (I know because it was a homework problem I had to do many years ago).
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
