01-06-2007, 01:38 PM | #1 |
Subwoofer Box for under bench seat
What do you guys think of this box? It's a little pricey at $190.
But the dimensions seem to be within spec for under a bench. i removed the cable from under the seat to make more room. Here are the dimensions: * 10" Dual Sealed * Chevy Avalanche 01-04 * Height: 7 1/2" * Depth: 14" * Top Mounting Depth: 5" * Bottom Mounting Depth: 6 1/2" * Width: 45" * Volume: 0.5 cu. ft. Per Chamber * 5/8" MDF Construction ACHV210 - Ground Shaker A CHV 210 10" Dual Sealed Anyone see any problems on why it may not fit? Thanks, Chad |
01-06-2007, 02:09 PM | #2 |
The Hammer Man
Re: Subwoofer Box for under bench seat
ttt
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
01-06-2007, 03:04 PM | #3 |
Why don't you fab a box out of cardboard 7" X 14" X 45" and see how well it fits your truck?
If the cardboard box fits, then you know that finished box would clear. If the box needs cut to clear obstructions, cut and trim the cardboard. When it fits to your liking, use the cardboard as a template to fab the final box out of MDX or plywood. |
01-06-2007, 03:11 PM | #4 |
senior member
if you are handy with a saw and a brad nailer i say go get a sheet of MDF and make that box ur self $190 would buy you like 5 sheets of MDF around here
69 GMC bagged |
01-06-2007, 07:17 PM | #5 | |
Like was mentioned.... slap together a cardboard box w/similar dimensions & test fit to get your answer. I know I've installed some of those pre-fabbed boxes for 8" subs (the ones available @ most stereo retailers) under the bench seat on one of my trucks. All I did was remove the hardware for the seat slider to get them to fit.
01-06-2007, 07:47 PM | #6 |
The Hammer Man
I'm with you man, 200.00 for someone else to do it is well worth it, just as long as it fits. This topic, speaker boxes and kick panels and audio set-ups must be the most difficult to get straight and simple answers to than anyother topics on the forum and the so called 'experts' are just not that helpful. IMO. it easier to get step by step help in rebuilding your transmission than sound advice on a suitable audio set-up for your truck. Good luck to you man. That box looks good, hope it works and if it does please let me know.
01-06-2007, 08:02 PM | #7 |
its all about the +6 inches
I don't have a bench anymore, but that looks WAY too tall to fit underneath a stock seat.
01-06-2007, 08:05 PM | #8 |
i have my own buisness doing custom car and audio and i can tell you that thats to think you can take the thinest lil cheapy walmart truck box that is supposed to go behind the seat and try and put it under it will not work you will have to make ur own lift blocks and lift the seat up a few inches to make any of them fit under the seat
01-06-2007, 08:10 PM | #9 | |
senior member
69 GMC bagged Last edited by pissonNOS; 01-06-2007 at 08:11 PM. |
01-06-2007, 08:21 PM | #10 | |
01-06-2007, 08:27 PM | #11 |
hmm i have had people bring them to me telling me to make them fit lol i never could get them to so i built them custom boxes but hey if ya got it ya did somethin i didnt lol
01-06-2007, 08:37 PM | #12 |
well, removing the adjuster stuff is one thing I never did when trying to fit stuff under my old bench... that may have been the ticket.
01-06-2007, 08:41 PM | #13 |
I always kept the seat as far back as possible so removing it didn't hurt anything for my application. I sold those boxes long ago but the next time I see some the same style, I'll get some measurements on them.
01-06-2007, 08:42 PM | #14 |
i would like to know as well cause i have tried them under my seat before but i didnt wana have to build a custom box for mine so i didnt bother anymore
01-06-2007, 09:56 PM | #15 |
Thanks for all the input. I agree with a lot of the comments. Especially the one from Boise.
I wonder though, Lets say I make just the box parts of it. How do you determine cubic feet?? I knew math would be used later in life....should have listened that day, instead of Please if you do the solution, out it in lamens terms Thanks, Chad P.S. I will be using if 10" subs if that matters. Most likely JL Audio. |
01-06-2007, 10:02 PM | #16 | |
Car audio is about ad obscure a topic as you can get. You will have people that say "I just tossed a $10 sub lose under the seat and it sounded great!" and other say "You have to spend at least $1000 to get any sound out of an old truck". You do what works for you and you alone. What someone else things sounds good to themselves, may sound like hell to you. You need to consider your budget, your skills, your taste in music, and how much time you want to invest. Car audio is not "one size fits all". Even if that box fits, do the speakers you want to run work in that style box? Is that enough/too much air volume? Is the a way to mount it once it's in there? If it were that easy, then it wouldn't be worth doing. |
01-06-2007, 10:08 PM | #17 | |
01-06-2007, 10:10 PM | #18 |
Well I just lines the entire floor and kick panels with Dynamat Extreme.
I ran out and am waiting on two more boxes to do the inner and outer sides of the doors. Then I will install the new carpet I got from GMCPauls as well as the new door sills. Then comes the pods from Christians Classics and then finally the 4 gauge wire and interconnects. I will be most likely going with the JL components with the 300/2 amp and the JL sub or subs and the JL 1000/1 I like all types of Rock not rap or hipity hop. Chad |
01-07-2007, 01:08 AM | #19 |
senior member
calculating volume as i can remember is Length x Width x Heigth
69 GMC bagged |
03-10-2007, 06:08 PM | #20 |
Ok, I'm gonna try to ressurect this thread for my own benefit....
Chadvicki, it's been 2 months...did you buy the Avalanche box and does it fit? What's a guy to do if he wants a little bit of wallop in a bench seat truck with a gas tank behind the seat? I know I had a pair of Kicker 8" subs in those "cheap" truck boxes about 15 years ago, and they sounded fine given the parameters, but what's everybody doing these days, and does anybody have pics? |
03-11-2007, 02:57 PM | #21 |
im glad this came back up i have been doing my own custom audio for many years but this one has got me stumped
Redneck Rampage 1972 Chevrolet C-10 LWB 350 1972 Chevrolet K-20 LWB 502 LiFtEd |
03-11-2007, 03:39 PM | #22 |
Freeeeee Mason...
I can draw you a box in SolidEdge if you'd rather build it yourself. I just need the dimensions. Tell me what subs you're getting too, and I'll give it the perfect amount of airspace. I've been drafting and building boxes for 3 years now. ALso, I've NEVER EVER heard one of those cheapy little crap boxes sound good. Your box is supposed to be specific for the sub you're using, not visa versa.
03-11-2007, 04:25 PM | #23 |
well im using a Fusion Powerplant 10in sub and im not sure of any kinda dimensions lol just want it under the pass or driver side of my bench seat without having to lift my seat
03-11-2007, 05:46 PM | #24 |
That's why sometimes you must match the sub to properly fit the intended box that fits within your specific space limitations.
03-11-2007, 05:53 PM | #25 |
Freeeeee Mason...
No, thats why you buy the sub and build a box to fit your application. I can see buying a specific shallow mount sub to fit within a restricted spot, but you can easily build a box to fit almost any restraint.
