Old 01-06-2007, 05:51 PM   #1
Madbomber88
Active Member
Madbomber88's Avatar
Angry Completely stumped with TBI prob
Ok, just finished installing a TBI conversion on my 72 K20 using a new painless harness and donor everything else.
Here's the problem...
It will start and run fine, but will not turn off. Everything else turns off (radio, heater, etc...) when I turn the ignition on, but the truck keeps on running. THe pink/black wire from the computer that is labeled "connect to ignition" is what powers the computer in the harness. I have connected that to a million different feeds that are only hot on start and run. But when you connect it to the pink wire, it fires up and runs, but stays hot when you shut it off. What does this mean?
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 01-06-2007, 11:05 PM   #2
Deuce
Deuce's Avatar
Re: Completely stumped with TBI prob
For trouble shooting sake try a wire from the battery with a toggle switch for any power wires to see if it still does the same thing.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 01-06-2007, 11:20 PM   #3
rage'nrat638
rage'nrat638's Avatar
I HAD A SIMILAR PROBLEM AFTER I INSTALLED MY MSD IGNITION..
i had to install the supplyed resistor after the alternator seemed just the littlest power from the alt spinning was enough to keep the truck running.
you might have a similar problem with the new wiring try pulling the wire on the alt after the keys turned off and see it the engine quits
just a thought
rage'nrat638 is offline   Reply With Quote
Old 01-07-2007, 01:30 PM   #4
Madbomber88
Active Member
Well I've tried all of that and still no luck. no matter what wire I hook that pink wire to, it makes it hot after running and turning the key off, but not off when it isn't running.
I have no clue but have temporarily gotten past it by installing a simple switch to kill it. So now I have to turn the key off and then flip the switch to turn the truck off...
71 Blazer CST
72 K20
Capt USAF
Old 01-08-2007, 11:48 AM   #5
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
Any More Pics Or Infor On The Tbi Swap?im Getting Ready To Do This,just Not Sure Of Using Factory Harness Or Painless Kit.you Said You Used Both?mind Telling/showing What You Did?thanks
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 01-08-2007, 03:51 PM   #6
Myself
I've experienced this run-on before in older vehicles. It's generally caused by a small amount of power backfeeding through the instrument cluster. A one-way diode attached in-line will cure the problem.
Myself is offline   Reply With Quote
Old 01-08-2007, 07:32 PM   #7
Madbomber88
Active Member
Hmmm...that might work, I'll give that a shot, thanks!
tallhodude, no pics yet but I will try to get some up tomorrow. I used a new harness from Painless and definitely recommend it, it is really easy to use. I also used a new painless harness for the truck wiring since I didn't want to hook up a nice new efi harness to the 34 year old wiring in the truck.
Talk about a spaghetti mess of wires...
other than that I used all donor parts from a 91 K5. Good thing too because I had to take the fuel pump relay off the used harness. I hooked everything up but bypassed the neutral safety switch, and knock sensor.
If you have any specific questions, let me know and I'd be happy to answer.
-Tim
71 Blazer CST
72 K20
Capt USAF
Old 01-08-2007, 07:40 PM   #8
Madbomber88
Active Member
What size diode do I need?
71 Blazer CST
72 K20
Capt USAF
Old 01-08-2007, 09:25 PM   #9
stsalvage
Scrapper 1
stsalvage's Avatar
what a about a voltage drop that the old trucks us to us but i hate computer crap
stsalvage is offline   Reply With Quote
Old 01-08-2007, 10:35 PM   #10
High Speed low Drag
High Speed low Drag's Avatar
I'm kind of slow abd maybe you already tried this but.....
Hook it to a circuit that is ONLY hot on the START position. Either that or you'll have to get a diode for the alternator and power it off of that.
High Speed low Drag is offline   Reply With Quote
Old 01-08-2007, 11:49 PM   #11
Greubin
Greubin's Avatar
-Tim
Hi Tim,
Just curious what the parts ran you for the TBI? I'm contemplating this upgrade
___________
Greubin
'71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI
Greubin is offline   Reply With Quote
Old 01-09-2007, 09:38 AM   #12
Madbomber88
Active Member
I got everything from a donor truck for $100 (this included intake, complete harness, computer, all sensors, TBI, distributor, all necessary brackets, and air cleaner assembly. The painless harness was the most expensive aroun $300. I had to modify the intake to match my heads, and that was no fun.
Other than that, the fuel pump from arizonatpi.com was about $175 or so but is a quality Walbro and came with both inlet and outlet filters. Lastly I bought some good aeroquip socketless fuel tubing that was simply awesome.
71 Blazer CST
72 K20
Capt USAF
Old 01-09-2007, 11:48 PM   #13
Greubin
Greubin's Avatar
Thanks for the info. What was the reason behind modifying the manifold? What engine are you running?
Thanks again
___________
Greubin
Old 01-10-2007, 12:51 AM   #14
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Newer heads have different angled bolts. Have to either shim the bolts or modify the manifold to match.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 01-10-2007, 01:10 AM   #15
Greubin
Greubin's Avatar
Ah ok that makes sense. I was surfing the trans-dapt website. Looks like they offer a carburetor-TBI manifold adapter plate..I wonder if that would work with an Eddy Performer manifold and TBI ?
___________
Greubin
