01-07-2007, 01:11 AM | #1 |
Out of the carpool lane.
How to get these 67 grill bolts off
I'm trying to straighten out the inner grill and need to cut off these rivets that hold it on. I've tried a 4" grinder and that won't work because it grabs too much and will ruin the pieces. A Dremel will take hours and, when trying to drill them out, they just spin and there's too little to grab on to.
Anyone got any ideas?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 01-07-2007 at 04:09 AM. |
01-07-2007, 01:21 AM | #2 |
KEEP ON TRUCKIN'
Re: How to get these 67 grill bolts off
Sounds to me like the Dremel and some patients. I have 3 grills I have to do that to. Maybe we will get lucky and someone will show us an easy way to do this.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
01-07-2007, 02:10 AM | #3 |
How about a drop of loctite where they are spinning and come back in a couple of days and try the drill again?
Jason |
01-07-2007, 02:15 AM | #4 |
I am a Referee of life.
Try reachin in from behind with a pair of Vise grips.Clamp the tail of the rivet and drill the head off.I haven't done it,it is just a suggestion.You only need to drill a 1/8 or so center out of the rivet.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-07-2007, 12:59 PM | #5 |
WTB:Patience and Talent
I just used a drill bit a little bigger than the rivet hole and then used a center punch or nail set to pop them out. Didn't damage grill at all.
69 shortwide |
01-07-2007, 01:20 PM | #6 |
i'd try using a larger size center punch and wackin it right in the center to tighten it up then a sharp drill about 1/4-5/16 inch to drill the head off// a too small a drill bit is sometimes the worst thing to use when removing rivet heads
01-07-2007, 02:33 PM | #7 |
If I remember correctly, I used a nail punch on the back side of the rivet, couple of wacks and its off!
'69 Fleet It ain't yours, if you didn't build it! |
01-07-2007, 02:52 PM | #8 |
use the drill bit thats the best way if you use about a 3/8 bit you don't even need the punch they just fall out took me about 10 min to do a grill and ive done 2 those are made out of aluminum and chew up fast...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
10-21-2007, 03:05 AM | #9 |
I ended up taking a Dremel with a cut-off wheel and carefully cutting the heads off parallel with the shank, at several different sides. They'd pop right through and I didn't have to deal with them spinning in the holes.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
10-21-2007, 08:14 AM | #10 |
Sharp chisel works the best! 2-3 whacks and they're gone.
'69 Chevy CST#'s 396/TH400, A/C |
10-21-2007, 10:24 AM | #11 |
67lwb
you can remove the entire grill and then place a pair of vice grips on the back. Drill them out and you should be ok. If it is the ones that hold the grill molding on they have a spring nut on the back of them
10-21-2007, 12:21 PM | #12 |
The problem with this is the chisel tends to want to keep going into something you don't want it to.
10-21-2007, 12:26 PM | #13 | |
Again, I was referring to the rivets holding the inserts in the core support, not the grill molding pieces.
10-21-2007, 12:33 PM | #14 |
Sierra Grande Club
I have a special chisel for my air hammer that keeps the chisel form cutting into the metal; it makes quick work with rivets. Or you could have used a right angle die grinder with a 2in disc.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
10-21-2007, 01:08 PM | #15 |
No, I couldn't have used either of these since you didn't bring them over!
10-22-2007, 01:00 AM | #16 |
use a 4 in grinder but use a flap disc intead of a grinding wheel, personally I use a flap disc for almost all my grinding just courser ones for heavier stuff, using one leaves the metal smooth and it wont grab hard and ruin the metal around it
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
10-22-2007, 02:23 AM | #17 |
The problem with using the 4" grinder with whatever you place as the 'sandpaper' is that you run the risk of it running off and in this case you'll end up with a damaged grill very easily.
10-22-2007, 04:37 PM | #18 |
Did it to mine and there was no damage just a steady careful hand, I do agree with a regular grinding wheel it can be hard to control and damage the grill, even if the flap disc does slip off it wont grind into it unless your bearing down on it
10-22-2007, 05:41 PM | #19 |
you should be able to grab the back o the rivit with some small needle nose vice grips while the grill is still mounted to the truck. I know that nornal regular vice grips wont work. good luck
1967custom |
