Old 04-24-2002, 08:12 PM   #1
slam33
slam33's Avatar
Post mix and match driveshafts
Anyone ever mix the front shaft off one set to the rear shaft off another set. Looks like I bent the big tube rear shaft on the truck and when I got out the sprare set of driveshafts to rebuild them with new joints and a center bearing, I found the front u-joint mount had been eaten away a bit on the inside of the hole and I think it's a little thin to take a chance. I have a good front and a good rear but there not balanced to each other.
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
Old 04-24-2002, 08:16 PM   #2
69 longhorn
Post
I have mixed the pcs. Some times you get lucky,but more often they need to be balanced as an assembly. good luck.......69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-24-2002, 10:04 PM   #3
Scrub
Collector of rusty Items
Scrub's Avatar
Post
Yeah, I have done it, but they will need a balance job.
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
