Old 01-07-2007, 02:22 PM   #1
C10 - C90 Bill
C10 - C90 Bill's Avatar
Looking For 3-Speed Manual Trans Ratios
Looking for the gear ratios on '60 to '66 3-Speed Manual transmissions.
Typically on a 6 cylinder trans.
Any info would be appreciated.
C10 - C90 Bill is offline   Reply With Quote
Old 01-07-2007, 04:22 PM   #2
b454rat
Re: Looking For 3-Speed Manual Trans Ratios
Dunno the numbers of the tree speed, maybe here??
http://members.cox.net/jeepinrandy/r.../transinfo.htm
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-07-2007, 04:35 PM   #3
ol Curt
Junior Member
ol Curt's Avatar
Here's the 4 speed, looking for the 3
GM Saginaw transmission ratio identification
# of grooves 1st 2nd 3rd 4th Notes:
0 2.85 2.02 1.35 1.00
1 2.56 1.81 1.37 1.00 Third gear on cluster has 25 teeth
1 2.56 1.81 1.44 1.00 Third gear on cluster has 21 teeth
2 3.11 2.20 1.47 1.00
3 3.50 2.48 1.65 1.00
*** The grooves are found on the input shaft. I am sure there are exceptions to this rule.
ol Curt is offline   Reply With Quote
Old 01-07-2007, 04:41 PM   #4
ol Curt
Junior Member
ol Curt's Avatar
I believe these are the different ones for the three speed...
Saginaw 3-speed 1st 2nd 3rd
No Lines (grooves) 2.85 1.68 1.00
1 Line (groove ) 2.54 1.50 1.00
2 Lines (grooves) 3.11 1.84 1.00
3 Lines (grooves) 3.50 1.89 1.00
Old 01-07-2007, 07:07 PM   #5
C10 - C90 Bill
Appreciate all the replies.
I should have mentioned earlier that the standard issue, non-synchro first gear trannys are what I believe are Muncie's. I did a little research and I believe they are SM 318 Muncie's which sound right to me.
b454, I searched the sight that you mentioned and saw just about every one but a SM 318. I also believe the last year GM used them was '66 or '67.
Curt, Do you know if the ratios you listed would also be for a SM 318?
Old 01-07-2007, 09:16 PM   #6
ol Curt
Junior Member
ol Curt's Avatar
Not for certain they are exact, but all were close to those listed.
Old 01-10-2007, 09:16 PM   #7
ol Curt
Junior Member
ol Curt's Avatar
I found 3 speed gear ratios for a couple of trannies listed for a 66 C10 if you're interested.
The service manual just lists a Saginaw 3 speed, a Borg Warner wide ratio and a BW Overdrive. The first two did not have a syncro first gear.
Let me know.
Bob (ol Curt)
Old 01-11-2007, 04:25 AM   #8
rwgregory
According to the GM Factory Overhaul Manual, May 1968 edition the SM 318 gear ratios are:
1st- 2:94 to 1
2nd- 1:68 to 1
3rd- 1 to 1
Rev.- 3:14 to 1
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 01-11-2007, 07:40 PM   #9
ol Curt
Junior Member
ol Curt's Avatar
The numbers I had were from the '66 Chevrolet Truck Shop Manual....I'll assume you no longer need them
Old 01-12-2007, 12:29 PM   #10
C10 - C90 Bill
Appreciate the replies.
Curt (Bob), Sorry I've been a little slow to your response, I've been away from the computer for a few days. The numbers rwgregory listed seems to be the ones that I have been looking for, but also wondering if they match with the info that you have from your '66 Shop Manual. (2.94 1st)
Old 01-14-2007, 01:42 AM   #11
ol Curt
Junior Member
ol Curt's Avatar
Yup, same
Old 01-14-2007, 11:49 AM   #12
C10 - C90 Bill
Yup, same
Old 06-15-2012, 09:26 PM   #13
rmccloye
rmccloye's Avatar
How do i get a hold of one those manuals? I'm rebuilding my SM318 this august.
rmccloye is offline   Reply With Quote
Old 06-15-2012, 11:09 PM   #14
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Looking For 3-Speed Manual Trans Ratios
Here you go:
http://67-72chevytrucks.com/vboard/s...=327764&page=2
http://www.nastyz28.com/chevy-manual...tification.php
http://67-72chevytrucks.com/vboard/s...ad.php?t=66523
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-15-2012, 08:55 PM   #15
rmccloye
rmccloye's Avatar
Red face Re: Looking For 3-Speed Manual Trans Ratios
Thanks. I am also on the search for some highway friendly rear end gears. I try to stick to two lane highways when traveling and even at 55-60mph my truck is whining. I've been looking and how comfortable do you think I'll be with 3.08 and sm318 with 700-15 tires? I hope to get an sm420 or sm465 soon but sticking to this for now.
