Old 01-07-2007, 03:07 PM   #1
cochino12
It followed me home?
cochino12's Avatar
best place to buy headers, bumper
I need to order some headers and a rear bumper for my 80 k10. Cant seem to find anything I like (cheap) on ebay and LMC seems really expensive. Any idea where I should order? thanks
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-07-2007, 05:32 PM   #2
wedgemon
wedgemon's Avatar
Re: best place to buy headers, bumper
I got mine at Summit (Right around the corner in Sparks, NV) Think I spent about $280 for Summit Headers (Blackjacks), Hooker Dual Exhaust (Fitted Pipes and clamps) & Summit Turbo Muffs - Loops over the rear axle and curves out behind the tire..
Took about 4 easy hours to install.
Kinda wish I'd not got the Hooker pipes and just put some pipes out in front of the rear tires - I like that look.
I can get the numbers off my receipt if you need em for your search.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 01-08-2007, 06:44 PM   #3
Duro5341
Duro5341's Avatar
I was looking at that kit, but getting the hooker headers instead
How did it fit with the transfer case, and how is it routed?, and pics?
Duro
Duro5341 is offline   Reply With Quote
Old 01-08-2007, 08:10 PM   #4
wedgemon
wedgemon's Avatar
Duro
Fit pretty well. The only issue I have is the passenger side tube around the T/C and over the crossmember needs about 12º of vertical bend to mate with the headers evenly ( I used Pepboys flex and made it up) Otyher than that it's straight forward. I would suggest using the Sawzall to relieve the tube to muffler mounting - gets kinda tough without the flare.
Next time The truck/daylight and me are home at the same time I'll try to grab pics.
- Dave
Founding Member:
Old 01-08-2007, 08:56 PM   #5
JESSEGALLEGOS
JESSEGALLEGOS's Avatar
If the truck doesn't see any road salt I would go for the Auto zone special. I spent $80+ not including the wrap nor silicone spray. My last set lasted for 6 years.
1982 BLAZER 2WD
http://img.photobucket.com/albums/v7...t/145c37fd.jpg
JESSEGALLEGOS is offline   Reply With Quote
