Old 01-07-2007, 03:13 PM   #1
gotmud
gotmud's Avatar
Wiring Help with donor column
I have a column from a 86 1500 that I am putting in. It has tilt.
The column is a auto shift on the tree.
The blinker switch has wipers (and a delay I think), high beams, cruise, etc. The bottom of the column there are several different connectors where about 18-25 wires terminate. Can anyone help with a diagram or advise on the wiring on it into my truck? I bought a universal wiring kit which is nice but doesnt pinpoint the numerious wires coming from the column.
In advance thanks!!!!!!!!!!!!!
Glenn
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 01-07-2007, 05:11 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Wiring Help with donor column
In case you don't know, a van tilt from a 72 - 81 van would be very close to a bolt on, and look totally stock. With this one you have now, you have an ignition switch with steering wheel lock and the other switches you mentioned that will be a bit of a pain to wire up, and then you'll have all the switches still on the dash to try and fill in or what ever. Not to mention, the one you have is a larger diameter that you'll have to do some mods just to get it to fit under the dash.
Old 01-07-2007, 06:07 PM   #3
gotmud
gotmud's Avatar
I knew that but I got the donor truck for free and already have it all bolted in with steering and all ready to roll....just wont crank without the copper in right.
Glenn
Cumming, Ga
