01-07-2007, 03:35 PM | #1 |
Outlandish Trends - FL
power steering hose routing
I just put in a new steering box (take-off from another truck), got new hoses, and pulled and cleaned my steering pump. Are my hoses routed correctly? I filled w/fluid and it seems like it has no power assist at all. Also, just for notes, I unscrewed the bigger nut on the bottom of the pump and when I pulled out the little nipple, I noticed a spring plate that seemed to close up toward the hole, but when I pushed the nipple back in and tightened it down, it went back into place, not sure if I screwed something up there, it didn't seem so.
-Bret 67 short-fleet sold! |
01-07-2007, 05:42 PM | #2 |
Re: power steering hose routing
Check out this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=221096
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-07-2007, 05:51 PM | #3 |
I saw that thread, but the pics aren't clear where the hoses go to the pump.
01-07-2007, 06:09 PM | #4 |
Well, according to the LMC catalog, I've got the hoses routed correctly. I can't figure out why I have no power steering. It's not whining or making any odd noises. The hoses are brand new.
01-07-2007, 06:17 PM | #5 |
laying low
Bret, have you put the front end up on jack stands, started it up and turned the wheel back and forth lock to lock? This used to be the proper way to bleed the steering system of air. I assume it still is. I put a used pump on mine and it simply is not pumping. New pump time for mine.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
01-07-2007, 06:20 PM | #6 |
I'll give that a try. Thanks Boog. If that doesn't work, it'll be new pump time for me also I guess.
01-07-2007, 06:53 PM | #7 |
both hose's go thru the rear part of the bracket.. looks like you might have some universal hose there..
there's more than likely something amiss with the check valve behind the fitting where the high pressure hose connects to. Last edited by rage'nrat638; 07-12-2007 at 06:59 AM. |
01-07-2007, 07:21 PM | #8 |
So is that hose the return line then if there's a check valve behind the fitting? I thought that was the pressure line.
01-07-2007, 07:42 PM | #9 |
no thats the high pressure line, with the check valve
01-07-2007, 07:50 PM | #10 |
hmm, then something must be amiss. When I pulled the nipple fitting out, that check valve flapper popped back towards the hole and the spring held it flush against the inside of the opening. When I stuck the nipple fitting into it, the opening of the nipple was the only thing pushing it in. Should it be offset? As it was, it looked like the plate from the check was sitting flush against the nipple, so if pressure was applied it would force itself closed onto the fitting. Is there a certain way that I need to re-install that fitting before hooking up the pressure line?
01-07-2007, 08:12 PM | #11 |
a pictures worth a thousand words i went and took some pictures from the manual
01-07-2007, 08:58 PM | #12 |
I've got power steering!!!! YaY!!!! I guess I just had to cycle it through the pump. Also didn't realize how much fluid that box holds! I had it up on jacks, and cycled the wheel like 20 times, then shut down, added fluid, repeated, and went through a quart & 1/2 of fluid! Boog and Rage'n'Rat, thanks a million for the help!! I truly appreciate it. This gets me one step closer to completion. Now I can mock my fenders back up so I can drive it up to my buddy's shop and start tearing it all down again.
01-07-2007, 09:33 PM | #13 |
no problem brother.. 67-72 service manual sent you a p.m. your pal mark
01-07-2007, 09:36 PM | #14 |
Thanks Mark!
01-07-2007, 10:07 PM | #15 |
just think you can become the new answer man on the board
01-08-2007, 08:21 PM | #16 |
laying low
Hey glad to hear it came around for ya.
