Old 01-07-2007, 05:54 PM   #1
pkj
engine?
just picked a 71 short step up yesterday. completly rusted out, but i wanted the frame for another project. engine is unknown as to what it is or if it runs, not the original engine, but guy said he thought it was a 305. the motor sits so far back in the 6 cylinder mounts i cant get to the back of the block yet. this thing has an alum. factory 2 barrel intake on it. the harmonic balancer has several differant size holes drilled in front, it is blue. any guesses? that drilled h.b. has me wondering. thanks, pkj
pkj is offline   Reply With Quote
Old 01-07-2007, 08:12 PM   #2
JimKshortstep4x4
Re: engine?
If you can read the suffix code on the engine pad, (right front of engine), then the engine can be identified. Just post the suffix code, (last three letters) and someone can tell you what you have.
Jim
Old 01-07-2007, 08:23 PM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: engine?
Where is this engine pad? Can someone post a picture of this for me? I was looking for my code the other day and what I thought was the code was something else.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 01-07-2007, 08:25 PM   #4
65-72 chevytoys
65-72 chevytoys's Avatar
Re: engine?
ON the front passengers side block pad just below the cylinder head and behind the Alt/AC depending on what you have mounted.
65-72 chevytoys is offline   Reply With Quote
Old 01-08-2007, 12:49 AM   #5
brak
brak's Avatar
Re: engine?
i snapped this pic from a block sitting in my garage.
You can see the flat section on the passenger side (directly above the waterpump bolts).
you may need to remove dirt or paint in order to see the numbers stamped in the pad. I usually run a razor blade over it, as it will leave said paint and dirt in the grooves, making the numbers easier to read.
The big numbers (letter size) will be the engine casting code, and usually there will be a smaller set stamped which will be the partial vin of the vehicle it left the factory in.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
