Old 01-07-2007, 08:32 PM   #1
patrolman1964
patrolman1964's Avatar
Klunking and knocking sound??
when i try to take off in first in my truck it makes a klunking knocking noise after clutch in fully engaged sounds like a u joint but its fine any thoughts.
patrolman1964 is offline   Reply With Quote
Old 01-07-2007, 11:50 PM   #2
MyakkaJeff
Junior Member
Re: Klunking and knocking sound??
Check the obvious first, I had this happen. Maybe loose tranny to bellhousing bolts. Missing or bad pilot bearing.
MyakkaJeff is offline   Reply With Quote
Old 01-09-2007, 05:12 PM   #3
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
There might be some play in the 3rd member. Put some blocks under the tires, and set the E-brake, then put the truck into neutral. Then twist the driveline to the left, then to the right. Does the driveline move, or is it solid?
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
