01-08-2007, 12:21 AM | #1 |
Wheels
I've got a 87 Gmc with 5 lug... Is 5x5 the only bolt pattern that will fit?
and i have stock rallys right now 15" i want to keep the tires do you think stock wheels are 15x8 or what?
1973 Chevrolet C20 (Under Construction) |
01-08-2007, 12:34 AM | #2 |
needin' money
Re: Wheels
yep, or uni-5 lug wheels, stock wheels are either 15x7 or if you are lucky enough they can be 15x8, need a pic to tell though
SWB Stands for Short Wide Bed |
01-08-2007, 12:40 PM | #3 |
Re: Wheels
My experience has been that trucks came with 15x8's and van came with 15x7's. Your experience may vary though?
If you look at the rim it should have the size stamped on it somewhere. I think on the rally's it is stamped on the back side but it might also be close to the valve stem hole. Either way, its difficult to see if the rim is dirty.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
01-08-2007, 05:03 PM | #4 |
Mad Scientist
Re: Wheels
I think most of the 80's trucks were 7"ers.
Everythang relates to Beer! 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger Last edited by hiway; 01-08-2007 at 05:03 PM. |
01-08-2007, 08:38 PM | #5 |
Re: Wheels
Here is my 86 with 8" rallies and 255/70/15 tires. Does yours look like this?
01-09-2007, 01:27 AM | #6 |
Re: Wheels
Well, somebody correct me if I'm wrong but the 15x7 wheels have the 2 inch deep "beauty ring" as opposed to the 15x8 wheels which have the 3 inch ring instead.
An easy way to tell without measuring the ring to figure out which one it is, is like this: The 2" doesn't go completley around the valve stem in essence its only a "U" around the stem. The 3" does go completley around the valve stem, kind of makes an oval around it.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
01-09-2007, 02:13 AM | #7 |
Re: Wheels
what is the biggest size rim i can install without modifying suspention or anything? 20s?
01-09-2007, 06:41 PM | #8 |
needin' money
Re: Wheels
yes, you can even fit 22's , it is all about the offset, and the tire size, there is no real answer to the biggest wheel you can fit, what are you looking to do and we can lead you to what you need
SWB Stands for Short Wide Bed Last edited by 82c10; 01-09-2007 at 06:42 PM. |
01-09-2007, 08:11 PM | #9 |
Re: Wheels
just want some shiney rims i am thinkin 20's MAYBE 22's what offset would i need and what kinda tires?
01-10-2007, 02:16 AM | #10 |
Until Seventy Times Seven
Re: Wheels
If you go with larger wheels, you may end up reconsidering a suspension drop. If so, you, may want to size your wheels to tuck, say like ~5" bs on a 10" wheel in the rear and a ~5" - ~5.25" bs for a 8" wheel in the front. What type of stance are you after? (Stock stance with 20s or 22s?)
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
01-10-2007, 02:28 AM | #11 |
Re: Wheels
yeah i just know nothing bout wheel sizes
01-10-2007, 07:41 AM | #12 | |
yeller
Re: Wheels
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
01-10-2007, 08:28 AM | #13 |
Re: Wheels
I'm not bashing the big wheel thing, but I wouldn't go 20's or bigger unless you do something with the suspension. Chip Foose said it best: You can't put a set of 20" inch wheels on just anything. You have to build the car around the wheels. I don't think 20's with stock suspension would look good at all. A set of 17's would look better if you want bigger wheels.
Just my .02
01-10-2007, 12:07 PM | #14 |
Re: Wheels
anyone got a pic with a 73-87 with eagle alloys? like the 028 model... i love them (5 star) i like blingy wheels but i like the race look better... i dont know what im gunna do... lol
just looking for something under $600 bucks for wheels
01-10-2007, 06:57 PM | #15 |
needin' money
Re: Wheels
yeah someone does, you could get the jegs-weld knockoff's for less then that, as for the 028 there is a guy that is/was in one of the armed forces, that either is fatguy or bought a truck from fatguy if i recall, do a search, and you can probably find it, it is an 86 gmc i believe
01-10-2007, 07:16 PM | #16 |
Sb 400 club
Re: Wheels
Give your local cregislist a try lotts of wheels on there cheap and close to you so no shipping.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
01-10-2007, 07:32 PM | #17 | |
Sb 400 club
Re: Wheels
http://67-72chevytrucks.com/vboard/s...ghlight=blazer
01-10-2007, 10:10 PM | #18 |
Re: Wheels
the jegs weld knock offs dont have 5x5 though i always see 5.475 and 5.5/5 or something like that doesnt it have to be 5.5
01-12-2007, 03:15 PM | #19 |
Re: Wheels
I've decided to buy Eagle Alloy 028 series... Now my question is... What size? I want to keep it 15" for now... so i was told i should try 15x8 up front and 15x10 in the rear, will this fit without any modifications?? is that too wide? and is that a good option??? give me some suggestions on which size
01-12-2007, 04:20 PM | #20 | |
needin' money
Re: Wheels
01-12-2007, 06:47 PM | #21 |
Re: Wheels
which would look better? and yes it has power steering..
01-12-2007, 07:56 PM | #22 |
Re: Wheels
What size tires are you running? 8's all around or 8's and 10's would look best IMO.
01-12-2007, 08:14 PM | #23 |
Re: Wheels
Yea, I had those wheels on my truck for a couple of months, but as soon as I bought new tires, I put my rally's back on. Rallys are great if you ask me, a nice Blingy beauty ring and a new center caps and they stand out as well as a set of aluminum wheels. Do you have any pictures of your truck as it sits? Anyway, Rallys are cheap, plentiful and WILL FIT, no questions.
Brandon |
01-12-2007, 10:39 PM | #24 |
Re: Wheels
i have the original chrome rallys with beauty rings and chevy center caps right now i have a few pics posted around this group... i plan on sellin em for whatever i can get and get these eagle 028 series wheels
01-13-2007, 12:23 AM | #25 |
needin' money
Re: Wheels
all 10's if you like the look
