Old 01-08-2007, 12:38 AM   #1
68burb
Who all has mounted newer seats in a burb
I have 97 tahoe seats for my burb but was wondering what all you guys have done for brackets???
68burb is offline   Reply With Quote
Old 01-08-2007, 01:37 AM   #2
boostat4500
Re: Who all has mounted newer seats in a burb
I've got bucket seats out of an 01' Silverado. Just drilled new holes and bolted them to the floor. Had to use spacers under the back to match the front hump in the floor. They are full electric, so I was able to then set the height how I wanted, but right in middle was very close to the stock bench height.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 01-08-2007, 08:34 PM   #3
72LoBurb
Yup, I'm comp-useless
Did you reinforce the floors when you bolted those seats in? Those seats have the seat belt mounted in the seat, correct?
I have read,in here, that the floor should be reinforced before bolting those seats in, because of the seatbelts being integral to the seat. In the event of an accident the load will be transferred from the seat to the floorboards, unlike our original seatbelts being bolted separate from the seat.
72LoBurb is offline   Reply With Quote
Old 01-09-2007, 12:26 AM   #4
trapperjack
trapperjack's Avatar
I traded a neighbor for these. Came out of a conversion van of some sort. Had swivel bases, but once I got those off, bolt holes lined up for the brackets that were on the panel wagon, not original. Preety easy, and really cofortable seats.
trapperjack
trapperjack is offline   Reply With Quote
Old 01-09-2007, 01:01 AM   #5
boostat4500
I just used big washers on each side of the floor board. Plus the bolts are going through the same thick ( reinforced ) area of the floor as the stock seat bolts so I'm not too worried about it. Yes, the seat belt is integrated into the seat.
Old 01-09-2007, 04:48 PM   #6
TyJ
TyJ's Avatar
Hey boost' you wouldnt have any pics of that install by any chance would ya?
also remember that you were the guy putin in a 6.0...
pics of that would be great also, got both those swaps going right now!
most importantly where did the ac pump end up and if it stayed stock location any pics of the frame notch?
thanks in advance
sorry for the mini threadjack
Ty
TyJ is offline   Reply With Quote
Old 01-09-2007, 10:57 PM   #7
boostat4500
Here's some before and after of the interior. Ty- I have a few pics of the engine but they came out blurry for some reason. I'll try to get some better ones and post those up tomorrow. Look for a new thread with them in it. In case any one was curious, that is the stock trans tunnel cover and it is removable still, without pulling the rest of the carpet.
Old 01-09-2007, 11:53 PM   #8
68burb
who's carpet kit did you use?
those seats look like GM wanted them to fit right in.
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's
1995 K2500 Burb as daily driver 350 with 193K miles
1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse
Old 01-10-2007, 12:07 PM   #9
boostat4500
I just bought a roll of auto carpet and did it myself. $60 versus $350 was a no brainer. The wrinkles in the carpet is from the speaker and door wires underneath.
Old 01-10-2007, 11:24 PM   #10
boostat4500
TyJ - check my other thread to see the engine.
Old 01-21-2007, 03:15 PM   #11
71Subman
71Subman's Avatar
I put 2001 Tahoe seat in mine. Like others, used hefty washers and as much of the original holes as I could. Had to drill new ones for the middle mounts, but the outside holes matched up pretty well.
Noise Makin', Gas Gusslin', Big Ass Metal Monster!
1983 3/4 4x4 P/U (the Sub is gone)
1967 Firebird (Drag racer)
1967 Firebird (resto in progress)
1999 Camry (Wifey's econo-rail )
1997 VW Jetta (Daughter's cruiser)
1989 Le Mans (just extra for the boys to drive)
71Subman is offline   Reply With Quote
Old 07-25-2008, 05:08 PM   #12
Frizzle Fry
Frizzle Fry's Avatar
FYI guys, I have a set of 2005 Burb/Tahoe 3rd row seats up in the FS section -> Link
Frizzle Fry is offline   Reply With Quote
Old 07-29-2008, 08:14 PM   #13
salvageit
I used some out of a 2003 crew cab. I just drilled new holes for the fronts, the rear was no so easy, to get them back far enough for my liking I had to modify the seat frame and the floorboard.
salvageit is offline   Reply With Quote
