Old 01-08-2007, 01:44 AM   #1
Boise69
The Hammer Man
Boise69's Avatar
pulling the cab
OK after much thought on this and weighing the pros and cons i've decided to pull the cab along with everything else.
Does anyone have a link that demonstrates the easy procedure to pulling the cab? a step by step perhaps? not really all the details just the important things to consider.
ANy organizing advice to keep everything straight?
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 01-08-2007, 02:23 AM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: pulling the cab
I have one for removing the front clip complete but not the cab
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-08-2007, 02:24 AM   #3
Boise69
The Hammer Man
Boise69's Avatar
Re: pulling the cab
I'd like that too please
1997 MBZ E420
Old 01-08-2007, 02:36 AM   #4
Fordeater
Junior Member
Fordeater's Avatar
Re: pulling the cab
i removed my cab using a cherry picker and some chains. I didn't approach very well. It was a disaster for me. Hopefully somebody else has some good tips so putting my cab back on will be easier.
Tearin em down and prayin they go back together
Fordeater is offline   Reply With Quote
Old 01-08-2007, 02:40 AM   #5
72armyswbtruck
Re: pulling the cab
I'm lookin for the link in the FAQ's, it's there I did it and it was posted to the FAQ's last year some time but now I can't find it.
Old 01-08-2007, 02:43 AM   #6
72armyswbtruck
Re: pulling the cab
OK Here is the linky link:
http://67-72chevytrucks.com/vboard/s...ght=front+clip
Old 01-08-2007, 08:51 AM   #7
Dean
Dean's Avatar
Re: pulling the cab
I've done it several ways with no problems but it is much easier now with my lift.
Dean is offline   Reply With Quote
Old 01-08-2007, 11:05 AM   #8
Joe67
67 is sold
Re: pulling the cab
I have used a cherry picker, 2x6 board and a 2.5" strap to remove and replace my '67 cab by myself a few times now
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 01-08-2007, 11:41 AM   #9
Billla
Billla's Avatar
Re: pulling the cab
I guess my big question is are there any problems with lifting it by the roof? I expect just a 4x4 or two would do the trick...but I worry about bending the thing...
Billla is offline   Reply With Quote
Old 01-08-2007, 11:52 AM   #10
krue
Designated A-hole!
krue's Avatar
Re: pulling the cab
I lifted mine with a 2" strap and a chainfall hanging in an oak tree with no problems. I left the doors on and slid the strap all the way forward in the door openings, then shut the doors and lifted away.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-08-2007, 12:23 PM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: pulling the cab
Is your cab gutted? I did mine that way to reduce the weight as much as possible. I lifted mine very much like shown in Dean's first pic. Worked very well. Be careful of your rain gutters. I used a piece of wood in that area to keep the straps from bending the rain gutters.
As you lift the cab, go slowly so you can make sure you have all the ground straps and misc. wires disconnected. Get the emergency cable and speed cable unhooked as well.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-08-2007, 01:31 PM   #12
pkj
Re: pulling the cab
lots of zip lock baggies and a sharpie. keeps all your parts organized, and make notes on bags. believe me you wont rember all this stuff when you go back to assembly.
pkj is offline   Reply With Quote
Old 01-08-2007, 05:11 PM   #13
71chevytruckguy
71chevytruckguy's Avatar
Re: pulling the cab
take everything out, and doors off. get a of 3 of your buddies, 2 on each side with the biggest guys toward the firewall and lift away. this things are front heavy. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 01-08-2007, 06:27 PM   #14
Chevyman680063
Chevyman680063's Avatar
Re: pulling the cab
This will come in handy when I go to remove my cab. I've thought about using the cherry picker idea. It would be better if I had a lift but then I would need somewhere to put the lift.
Chevyman680063 is offline   Reply With Quote
Old 01-08-2007, 06:46 PM   #15
72 cheyenne pdx
72 cheyenne pdx's Avatar
Re: pulling the cab
Rokcrln has designed a cab and bed lift that hooks up to a cherry picker. Here is the link. http://67-72chevytrucks.com/vboard/s...06#post1941906
72 cheyenne pdx is offline   Reply With Quote
Old 01-08-2007, 07:05 PM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: pulling the cab
Here's a method I saw posted a couple days ago.
http://www.67-72chevytrucks.com/vboa...d.php?t=222143
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-08-2007, 09:31 PM   #17
72armyswbtruck
Re: pulling the cab
I think that I would leave the doors on just to help keep the cab from tweaking if you can. Did anyone else have any problems with the cab tweaking?
Old 01-08-2007, 09:38 PM   #18
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: pulling the cab
Take front clip off, take doors off, remove seat and tank, and get three buddies to help you pick it up and set off the frame. be carefull, as the bare cab is a little front heavy. One man can easily tip the cab from the normal position onto its back, though I recomend a dolly. These cabs are really light totally gutted out. I've got an old beat-up junk cab that I can load and unload into the bed of my truck by myself. You will, of course, want to take more care if it is a cab you are working and don't want dented/glass broken.
If you are doing a cab swap, and the old cab is really rotted/dented, it is also real easy, after unbolting it, for one person to just roll it off the frame.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 01-08-2007, 10:16 PM   #19
gyjackson
Re: pulling the cab
I've done it three times without a "tweak". Fortunately I have a loader on my tractor which makes it pretty painless. I have done it with and without the doors. Last time without doors, with all interior still inside. Put a 4x4 through the door openings as far forward as possible, a chain on each end tied to the loader bucket, unbolted the mounts, unhooked the steering at the rag joint, cut the heater hoses and wind. washer hose, unhooked the temp. sender, oil pressure line, and speedo cable, dropped the shift rod, pulled the wiring harness apart at the firewall, slipped the wires out of the gutter, unhooked the throttle cable and e-brake cable, and ground staps. then up I went.....OOPs, broke the fuel line...and lost about 5 gallons of gold till I got the can under it. After It was on the ground I removed said 4x4 then bolted the doors back on for safe keeping of the interior till later. No bends, no tweaks, no errors.
gyjackson is offline   Reply With Quote
Old 01-08-2007, 10:31 PM   #20
msgross
msgross's Avatar
Re: pulling the cab
has anyone put a cab on a rotisserie to turn it upside down and work on the bottom? I plan on making a "litter" style jig to bolt the cab to then mount to a rotisserie and be able to work on the bottom of the floor while standing or sitting..... I would die if the thing fell off and ruined my only cab!
msgross is offline   Reply With Quote
Old 01-08-2007, 10:58 PM   #21
Boise69
The Hammer Man
Boise69's Avatar
Re: pulling the cab
Thank you for that! That was what i was looking for. I plan to strip the interior completely and doors, glass in, and use my fork lift and a 4x4. should be simple. thanks forum
1997 MBZ E420
Old 01-08-2007, 10:59 PM   #22
msgross
msgross's Avatar
Re: pulling the cab
don't forget brake lines and all ground straps...
Old 01-08-2007, 11:01 PM   #23
longhorn71
longhorn71's Avatar
Re: pulling the cab
same idea just a different truck..............we lifted an 85 blazer body during a swap this summer (sorry no pics tho)the only thing that was missing from the inside was the column.used a 4" wide cloth sling through the door opening and the back of them clivesed (s/p?).another sling was used through the rear wheel wells and brought up above the top.clivesed(s/p?) the ends togther.put a 4X4 block of wood through the two loops.wrap a chain around the center of the 4x4 hooled to a chain hoist and lift.
longhorn71 is offline   Reply With Quote
Old 01-08-2007, 11:25 PM   #24
gyjackson
Re: pulling the cab
You bet hammer man, happy to help!!
Remember, like they all say, check it close to make sure everything is disconnected. When you pull it up with the fork, go up about two inches then stop. Get off and look it over again. Bet you find somethin' else hanging on. Never fails no matter how much you do it. Cut it loose then give it a shake for good measure.
