![]() Join Date: Aug 2005
4L60E Swap
I might be able to get my hands on a 4L60E pretty cheap so I'm considering swapping it out in place of my old Saginaw 3 spd.
How difficult is this swap? I'm not doing it but the more difficult it is the more it's gonna cost me. Is this a worthwhile swap? I'd like to have the OD for highway driving. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: 4L60E Swap
Click on the search button above your post and type 4l60e swap. Hit enter and it will take you to some threads on your question. the 4l60e is computer controlled and needs the harness from the donor vehicle or a special harness for it to shift properly.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Questionable
Re: 4L60E Swap
Good reading: http://www.novak-adapt.com/knowledge/th700r4.htm
What I think you need: http://store.summitracing.com/egnsea...=+115&y=9&x=30 Or: http://www.eatmyshifts.com/pl_4l60e.htm#Compushift 4l60e is an electronic version of the 700R4. Is it worth the $$$ to spend buying the harness when you could just get an '87 or later 700R4? The 700R4 from '87 on is supposed to be pretty dang reliable.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Questionable
Re: 4L60E Swap
PS - I don't know what is required for clutch/flexplate/flywheel changes, if any. It should technically bolt right up. You will need to get a different tranny crossmember - the automatic for your year of truck (I have a spare with new hardware if you're interested - I refurbed it and have pics...).
It is a direct boltup to the crossmember and it should fit in the stock position with the stock crossmember. I believe TH350 and 700R4 are same length, if this is true, then 4l60e and 700R4 are the same tranny, so ... you do the math ![]()
its all about the +6 inches
Re: 4L60E Swap
the crossmember will need to be obtained, and placed in a non stock location (the 200 4R is the one that bolts in the TH400 position) You'll need a stand alone computer, I don't have any numbers, but get rready for sticker shock.
Not worth it. |
Re: 4L60E Swap
Thanks for the info all, you pretty much confirmed what I was thinking. I can get a real nice deal on that 4L60E but by the time I shelled out all the $ for install and electronics it wouldn't be such a good deal after all. If only it were a 700r....
Questionable
Re: 4L60E Swap
Andy, are you sure about the bolting into non-stock location thing? You can take an LS1 with a 4l60e and it bolts using the stock AT tranny xmember right in the stock framerail holes with no modifications. I can't imagine that any stock engine is much different.
I honestly don't know what kinda engine he has in his truck, but...depending on how far back it sits, I'd not be surprised to see that it would be a direct boltup.
Re: 4L60E Swap
well, the 700R4, bolted to a small block int he stock location, needs moved.
The TH350 from front edge to tranny mount is 20 3/8 inch... regardless of shaft length. The TH400 from front edge to tranny mount is 26 15/16 inches. The 200 4R from front edge to tranny mount is 27 inches the 700 R4 from front edge to tranny mount is 22 1/2 inches |
Scrapper 1
Re: 4L60E Swap
I like saying this to all the wonderful people that like putting computors in a such a easy truck to work onwhen you add a computor i feel your better off buying a new truck with new problems when you rigg it well i say plan not to by a new house cus it will cost you a furtune to find all the probems that are hood with computors but thats me Old cars and trucks is suppost to take you back to that simpler time and i think if you make it easy and it will get you from point A to point B and the 700R4 from 1987 and up is the best one leave the coputors to the new cars and trucks leave it all close to factory as possible cus when you need to fix it its better to go throw 1 or 2 manuels to fix your truck but you get into the newer stuff the new people that work on it wont understand what you did and the oldpeople the own the same truck will shake there head
Re: 4L60E Swap
while I can agree with that....I have to say, once you have the proper diagnostic tools, and learn the computers, it's awsome being able to plug in and know what's wrong, and the hood hasn't even opened nor your hands got dirty yet.
Don't fear the new or unknown... just tread lightly. ![]() |
Questionable
Re: 4L60E Swap
Old trucks are outdated. If you have the brains to figure out how the computerized system works, and you can pull it off, go for it.
If you stick with the old and easy, have fun buying gas with that 4MPG setup....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 01-08-2007 at 10:00 PM. |
