01-08-2007, 03:35 PM | #1 |
1972 c20 3/4 ton
can anyone tell me how to tell what kind of transmission is supposd to be in my truck? i know it is a short shaft, and has the square 350 pan on the one in it now, plus a drain plug, not original i am assuming, will not shift into third, and i want to replace with a th350 short shaft, but not sure if that is good enough, no towing, or hauling, just regular daily driver. anyone near Austin texas have a nice used one untill i can get mine rebuilt?
01-08-2007, 03:38 PM | #2 |
its all about the +6 inches
Re: 1972 c20 3/4 ton
if it has a kick down cable, it's a short shaft TH350 (which DID come stock with a drain plug)
If there is no kickdown, it's a TH400. |
01-08-2007, 11:49 PM | #3 |
That's a TH350, the one in my '70 K20 Suburban is original and it has a drain plug also. I don't think there was a short tail TH400, at least I've never seen one. The 400 in my truck is a 1967 long tail.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
01-08-2007, 11:56 PM | #4 |
That's the only problem,that it won't shift into 3d?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
01-09-2007, 12:41 AM | #5 |
A short tail t400 came in alot of pass cars. There are long tail 400's that came in some trucks and older wagons anf 400's that came in 3/4 and 1 tons with no slip yokes.
01-09-2007, 12:46 AM | #6 |
My 70 originaly had a short tail 400.... But it had a big block too.
01-09-2007, 01:10 AM | #7 |
New Member
pretty sure mine is a short TH400 but its connected to a BB in a longhorn
01-09-2007, 02:35 AM | #8 |
Go with a cheap $400 dollar rebuilt transmission from autozone, that's what my 350 replacement cost me
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
01-09-2007, 08:49 AM | #9 |
Who says you need a bebuilt? Unstick the governor,check the modulator.Check vac line to modulator. All real easy stuff,maybe 1 hour max.-cougar
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 01-09-2007 at 08:49 AM. |
01-09-2007, 05:44 PM | #10 |
yes the only problem....
01-09-2007, 08:07 PM | #11 |
Take the vac hose off at the modulator (on the trans). Any fluid? Then you need a new modulator. Uncrew it and screw in a new/used unit. Check the line for leaks.A vacuum leak on the modulator line will cause it to not shift up. Then if it still doesn't shift up take the round cover off the governor on the side of the trans.and free up the governor,cause they occasionally get stuck with grit. It will now shift up.
If not,post again.-cougar
