Old 01-08-2007, 04:39 PM   #1
Woogeroo
Question Rochester B - rebuild questions ?
I have a thread about this over in the engine shop:
http://67-72chevytrucks.com/vboard/s...d.php?t=222218
I thought maybe you older truck guyy might have some ideas tho'...
-W
-- original post below --
according to the rebuild instructions, this part is called : plug - power valve
http://chevy.tocmp.com/1929_57chevyparts/57cmpc0295.htm
At the page above, on the diagram the part is referred to as: 3.858 valve unit.
My Dad and I think that ball is not supposed to be stuck down in there like that.
We've tried compressed air, PB blaster... no joy so far.
And now we have a spring that took off flying from the rebuild kit, ha! old trucks are fun!
Wish us luck trying to find that spring... haha...
Thanks,
-W
Woogeroo is offline   Reply With Quote
Old 01-08-2007, 06:16 PM   #2
pgf545
pgf545's Avatar
Re: Rochester B - rebuild questions ?
I don't know about your particular carb, but I would think that ball should be free. Holley uses a rubber diaphram and I have done tons of them. My guess is that Rochester uses the ball along with a spring that senses vacuum to open it.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 01-08-2007, 07:56 PM   #3
Woogeroo
Question Re: Rochester B - rebuild questions ?
Dad managed to get the ball out of the part in question... he left it in the carburetor cleaner bucket for two days and it rolled right out. I guess it was gunked up good.
Simple solutions are good.
However, as with all things old chevy truck, he has encountered another issue on this carburetor rebuild.
Using the above diagram... the following parts are missing, the hole was filled up with 'goop' as dad called it. I wasn't there when he discovered this.
The parts missing:
spring 3.823
screw 3.822
Those parts are not in the rebuild kit, as I imagine that they are supposed to be reused.
Anyone have an idea of how to acquire these parts... I would imagine that they would have to be used?
-W
Old 01-09-2007, 01:30 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
If I had an extra carb, I send you the parts. It's the idle mixture screw. Go over to the bolt, someone there, like hotrod lincoln, should be able to help.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
