Brake pedal question
I have a question on the brake pedal. Is there a difference between manual and power of where the rod attaches to the pedal arm? I have the booster with brackets and the correct linkage rod through the firewall but just curious if the attachment hole is different for manual vs. power. I have 5 pedal assem's that all have the same hole. I'm sure they are power pedals but just curious if there is a difference.
TIA - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
its all about the +6 inches
Re: Brake pedal question
the pedal is the same p/n for manual or power assist
Yep, pedals are the same, but beware of the mal-adjusted master cylinder rod. I did the swap with mine and the rod was adjusted a bit long. It took me forever to figure out why the brakes began to tighten up after driving (and stopping) repeatedly.
I have heard of guys mounting the rod lower on the brake arm after a power upgrade but don't know if it's necessary. Something about not needing as much pedal to stop and it makes the brakes less touchy.
generally the P/B rod will mount about an 1 1/4 lower than where a manual rod would mount
Active Member
I was curious as well, my 2 conversions are touchy, almost kissed the windshield on the first stop, but after 24 years of having to stomp the pedal, it takes some retraining...
Never try to teach a pig to sing; it wastes your time and annoys the pig! ![]() ![]() My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
QKsilver, what do you base that info on?
