Old 01-08-2007, 11:27 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Harmonic Balancer issues.
I’ve been prepping the motor with fresh new alternator & power steering brackets. I have a new water pump pulley coming from Southern Parts.
While looking at everything I noticed something out of whack on the crank pulleys. What I found is the rubber on the HB is starting to push out a little.
Is this something that need immediate attention or can it wait? The balancer is not loose or anything just a little of the rubber is stating showing.
I searched for some answers and found some that confused me-(not that hard to do) lol.
I read that older engines had small HB’s. Mine is a large 8in and looks like Ragen’rat’s.
(Except his looks really nice with a chrome pointer and all)
It’s also on a short water pump. Does all this sound correct?
Thanks.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 01-09-2007, 12:15 AM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Harmonic Balancer issues.
sound's right..i might have a nother used one or you could just buy new for
45.00-55.00
rage'nrat638 is offline   Reply With Quote
Old 01-09-2007, 01:15 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Definitely put in a new balancer while it's apart. The size is determined by your pointer, which can be replaced if needed. But you can buy 8" balancers all day long, so stick with that size.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-09-2007, 01:19 AM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
Don't know if this helps but when I had a motor put in recently I saw the same thing and decided it was OK. Now 12K later the TDC mark is about 20 degrees advanced,so I suspect that the thing is slipping internally. I'd get another one.make sure the seal surface is good or get a sleeve installed.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-09-2007, 08:02 AM   #5
Sport/Truck
Sierra Grande Club
Thinks everyone, I think I’ll get a new one. Cougar, what are these seals & sleeves you mention? I understand the seal in the block, Can/should I change this while im in there? I don’t any evidence of oil leaking there though.
I don’t know what the sleeve that cougar mentioned is? Any information would be appreciated.
s/t
Old 01-09-2007, 08:03 AM   #6
70c10
67-72 Addict!
70c10's Avatar
I got a nice summit racing brand with the engraved timing marks for about $60last year.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-09-2007, 08:41 AM   #7
WorkinLonghorn
It's been a few years since I did it but I thought on mine,the HB had a surface that the cover seal rode on.On mine it developed a groove there so they pressed on a sleeve that restore that area to a sealable surface.
Memory is pretty dim though so please chime in if I'm full of it.-cougar
Old 01-09-2007, 09:59 AM   #8
cdowns
cdowns's Avatar
while working on the front of the engine you might want to take off the timing chain cover and check the chain for wear // replace timing cover gasket and crank seal it's inexpensive preventive maintenance
Old 01-09-2007, 12:05 PM   #9
Sport/Truck
Sierra Grande Club
I’ll check it out. Thanks.
s/t
Old 01-09-2007, 12:06 PM   #10
Sport/Truck
Sierra Grande Club
I’ll look into gear drives too.
s/t
Old 01-09-2007, 02:19 PM   #11
mrein3
mrein3's Avatar
A stock harmonic balancer will develop a groove where the oil seal rides around. This will eventually leak.
There are two fixes for this leak.
1. Buy an offset seal to replace the stock one. This will move the point of contact with the balancer and stop the leak for another 100,000 miles.
2. Buy a sleeve for the balancer. The sleeve gets whacked on over the groove giving the seal a new surface to ride.
Wait, I guess there are three fixes. The third would be to buy a new balancer.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-09-2007, 02:25 PM   #12
Sport/Truck
Sierra Grande Club
I’m looking for a stock type of balancer OEM was 131! Ouch.
An engine shop here quoted me 60 for a pioneer brand.
Napa said 65 for the bulkamp brand – all thee are new.
Commits?
s/t
Old 01-09-2007, 02:31 PM   #13
Sport/Truck
Sierra Grande Club
Looks like the pioneer is the brand summit sells for more money. I’ll go look at it after work.
s/t
