Old 01-09-2007, 12:37 AM   #1
corn
C notch plans?
Anyone have prints or plans to make your own c notch? Id like to make some for my truck but dont know where to start. I thought about buying a set & cloning myself a set at work & reselling them but thats just a pain...
corn is offline   Reply With Quote
Old 01-09-2007, 02:54 AM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: C notch plans?
What is a C notch?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-09-2007, 08:32 AM   #3
AKChevyman
Chevy Forever
AKChevyman's Avatar
Re: C notch plans?
That is a notch you cut in the frame above the rear axle so it will sit lower.
My first love
1971 C20
Hugger orange
Getting face lift and heart transplant .30 402 BB /TH400 and GV
Wifes car
1969 Chevelle SS 396 325hp/TH400
Factroy A/C Automatic w/ Floor shift console.
restored.
AKChevyman is offline   Reply With Quote
Old 01-09-2007, 08:55 AM   #4
72armyswbtruck
Re: C notch plans?
Thanks, To the Top for you
Old 01-09-2007, 09:38 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: C notch plans?
Corn, I don't have any plans but here is what they did with mine. It should be very easy to duplicate even though your frame is different.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-09-2007, 07:19 PM   #6
corn
Re: C notch plans?
WOW! That looks easy enough. Thank you!...
Old 01-09-2007, 09:08 PM   #7
Dowdy
Re: C notch plans?
I just used a good old piece of schedule 40 pipe. If you pull the springs and set the frame down on the axle, you will know where to center the cutout.
Dowdy is offline   Reply With Quote
Old 01-10-2007, 12:03 AM   #8
shifty
Questionable
shifty's Avatar
Re: C notch plans?
^^ That's what I keep seein everyone doing. I just didn't know what size it was.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-10-2007, 12:10 AM   #9
brak
brak's Avatar
Re: C notch plans?
That's what i was thinking...
except i will probably box the frame in.
are you going to add a bumpstop?
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 01-10-2007, 12:21 AM   #10
corn
Re: C notch plans?
Looks like 6" to me. Will the frame have to be all braced up when you cut & weld? Or just cut it & weld it in with the wheels on the ground?...
Old 01-10-2007, 12:28 AM   #11
SCOTI
SCOTI's Avatar
Re: C notch plans?
Support the frame in front & behind the area being cut (& welded on) or it will tweak on you.
It would be wise to weld a boxing plate in before cutting for insurance/extra strength. Then, 'c' the outside of the rail & the new boxing plate. Grind the excess material off from the cut. Put the 6" pipe in & weld it all up.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-10-2007, 12:32 AM   #12
corn
Re: C notch plans?
Hmmm, I was thinking that you would weld the tube all in & then cut out the part you want gone. Wouldnt that keep it all aligned better while you install it?
Old 01-10-2007, 01:38 AM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Re: C notch plans?
My thoughts exactly. Weld in the tube, weld on the boxing plate, cut the two semi-circles out. Makes sense in my head at least...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-10-2007, 11:16 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: C notch plans?
It can be done both ways. As you can see from the pics here Roger at Stoked Out prefers to box the frame first to prevent any chance of it flexing. Once it is welded in solid you can weld the section of pipe in on both ends.
Articles-
"Refining Sierra"
Old 01-12-2007, 01:57 PM   #15
pharcyde05
pharcyde05's Avatar
Re: C notch plans?
yes that is how i have done it in the past box in frame for support then cut out C and weld in tubeing
pharcyde05 is offline   Reply With Quote
Old 01-13-2007, 04:16 PM   #16
corn
Re: C notch plans?
I snatched a piece of 6" tube from work yesterday. Its 1/4" wall & about 10" long. Now I gotta get the plates made & the tube cut.
Old 01-16-2007, 10:18 PM   #17
action
Active Member
action's Avatar
Re: C notch plans?
Just did mine yesterday-6" 1/4" not finished yet but getting there.
Jack
action is offline   Reply With Quote
Old 01-16-2007, 11:26 PM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
Re: C notch plans?
Anyone have any suggestions as to where to look for some of this locally? Generally speaking that is. What type of places would have small pieces for purchase or scrap? Everything I find is in 20' lengths. Don't think I need that much...
Thanks -Chris
-Chris
Old 01-17-2007, 12:08 AM   #19
SCOTI
SCOTI's Avatar
Re: C notch plans?
Thanks -Chris
Most steel yards will have 'drop' steel or scrap pieces that they sell for less than the price of a full piece but it will be more $$ per pound vs. buying bulk.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-17-2007, 12:27 AM   #20
Shane
Shane's Avatar
Re: C notch plans?
I purchased some a few years ago from a local steel dealer. He cut the length I needed off of a 20' section ... sold it to me by the pound.
Shane is offline   Reply With Quote
Old 01-17-2007, 08:20 AM   #21
Rokcrln
Rokcrln's Avatar
Re: C notch plans?
Thanks -Chris
Find a construction site and get a drop from the sprinkler guys!
Rokcrln is offline   Reply With Quote
Old 01-17-2007, 09:53 AM   #22
dave2953
Dave's not here, man
dave2953's Avatar
Re: C notch plans?
This is probably a dumb question, but what do you use to cut the "C" shape in the frame? I only have cutting wheels and don't see how you could do it via that method. Thanks!
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-17-2007, 10:10 AM   #23
gringoloco
A guy with a truck
gringoloco's Avatar
Re: C notch plans?
Plasma if you're rich. If you're like me, reciprocating saw or jigsaw.
-Chris
Old 01-17-2007, 10:34 AM   #24
action
Active Member
action's Avatar
Re: C notch plans?
I used what is called a speedy cut. It is a 7" "thin" cut off blade for a small grinder. It is thin so it kind of bends when making a circle. You have to hang on and use gloves-If not careful they will eat you.
I cut the 1/2 circle out of the side of the frame slid my pipe in and fit it up then welded it. Then I went back and cut out the bottom of the frame. Stayed nice and straight
Jack
Old 01-18-2007, 12:54 AM   #25
Rollie396
someday it will be done!
Rollie396's Avatar
Re: C notch plans?
I'll warn against using a zipcut to cut an arc like that.Those discs are not meant to bend.When one of them flies apart it happens real fast.
A young kid around here was killed by one last year attempting a similar task.The disc exploded and a piece of it pierced his heart.
If you don't have access to a plasma or oxy/acet torch,a jigsaw will work fine.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
