Old 01-09-2007, 03:39 AM   #1
70-c10LWB
do i need a new mastercylinder?
I am about to order my disc brake/drop spindle kit from gmc pauls most likely and do i need to get a new master cylinder or can i use a proportioning valve. thanks everyone
70-c10LWB is offline   Reply With Quote
Old 01-09-2007, 03:47 AM   #2
ghetto_superman
ghetto_superman's Avatar
Re: do i need a new mastercylinder?
if you currently have a drum/drum then youll need a new prop valve IIRC..
if you dont already have power brakes you can get the whole setup (pedal rod,bracket,booster,MC,propvalve)on the cheap out of a 73+ truck...
something to ponder
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 01-09-2007, 05:37 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'll need BOTH a new master, and prop valve in order to do it properly
Old 01-09-2007, 11:05 AM   #4
70-c10LWB
thanks for the rply. also is the brake booster for my truckk fine. i have drum/drum
