Downshift cable adjust
What's the proper way to adjust my downshift cable on my 86 with a TH350? Since I've put my Holley on it won't downshift at full throttle.
86 GMC C15 swb. 350/TH350, fully loaded, but wish I had overdrive! |
Re: Downshift cable adjust
won't down shift?? or up shift???? if it doesn't down shift you need to push the the button down and open the throttle all the way (with the engine shut off) and if you do that and there is still slack in the cable...you need to push the button and push the cable back in by hand and repeat the process again
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles ![]() '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L ![]() ![]() ![]() |
There's no button...just a screw on stop in front of the throttle lever on the carb. It's a TH350, so it's not a TV cable like on TH400's or TH700's. This cable only controls downshifts.
Can someone post or email me a pic of a factory cable for a TH350 trans? I'm starting to think the transmission shop put on a universal aftermarket one instead of a OE unit.
