Old 01-09-2007, 11:19 AM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Question Question about using a 78 3/4 ton master
I have removed a manual brake master from my 1970 K5 and have installed a master cylinder, booster and proportioning valve from a 1978 3/4 ton.
I removed the donor parts quite some time ago and I don't recall which reservoir is supposed to feed the front as opposed to the rear.
I currently have it hooked up with the front reservoir going to the proportioning valve to feed the front brake lines. I know I have read that our year 3/4 ton truck's have the front brakes fed from the rear reservoir but don't know if that holds true for a 78 3/4 ton.
Any one know? I posted over in the 73-up section but doesn't look like anyone there knows the answer to this question.
Here is how mine is presently ran
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-09-2007, 11:23 AM   #2
cooters
Re: Question about using a 78 3/4 ton master
the master has a smaller and a larger resevoir, the larger resevoir is always for the disks
cooters is offline   Reply With Quote
Old 01-09-2007, 11:50 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Thank you!
