01-09-2007, 12:07 PM | #1 |
Engine Storage
How long can you store an eng block, after its been to the machine shop, wrapped in plastic, just the block, no crank, pistons or heads on it, before it should go back to the machine shop for a clean up??
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
01-09-2007, 12:14 PM | #2 |
Re: Engine Storage
The machining will stay good forever you just have to keep it from rusting. I'm sure someone will reply with some suggestions for what to coat it with prior to wrapping it in plastic. It's probably a good idea to unwrap it periodically and re-coat it to prevent rust.
Just my thoughts. Please correct me if I am wrong.
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts! |
01-09-2007, 12:19 PM | #3 |
Re: Engine Storage
I agree,you definitely need to coat it with something as it will rust rather quickly.Maybe you should get hookrd up with the member offering the deal for us on the Gibbs product.
http://67-72chevytrucks.com/vboard/s...d.php?t=221944 Last edited by jamesi20; 01-09-2007 at 12:24 PM. |
01-09-2007, 12:35 PM | #4 |
Re: Engine Storage
I already did, thanks, I've coated it with wd40, and where it won't run off, oil.
01-09-2007, 12:48 PM | #5 |
Re: Engine Storage
Eastwood makes some "self healing" rust proof. It is tan in color and dries to a soft texture that can be scraped off then cleaned with kerosene. I would put this on all machined surfaces. Then pour oil in the oil galleries and plug with a rag or paper towel. Last wrap the whole thing in wax paper of brown paper and covr with a bed sheet. The paper will protect, but not hold in water vapor like plactic will.
trailers are for boats |
01-09-2007, 12:58 PM | #6 |
Re: Engine Storage
Just use the Gibbs. And re-plenish as needed.
01-09-2007, 01:28 PM | #7 |
Re: Engine Storage
Thanks for the info.
01-09-2007, 02:24 PM | #8 |
Re: Engine Storage
Wash it thoroughly then go ahead and paint the outside. Wipe down the bearing surfaces, bores, and lifter bores with grease. Put it in plastic and store it indefinately.
01-09-2007, 02:28 PM | #9 |
Re: Engine Storage
I've stored one for years and as noted it's all about preventing rust. I use WD-40, but others have reported good luck with LPS3 and other lubricants. Lube it up, bag it and don't worry about it When you're ready to use it, then just start the washing process with a bit of water-soluable solvent.
01-09-2007, 02:29 PM | #10 |
Re: Engine Storage
01-09-2007, 02:31 PM | #11 |
Re: Engine Storage
Yes, it will need to be dry first (compressed air) even before painting. I thought that was a given, my bad.
01-09-2007, 02:55 PM | #12 |
Re: Engine Storage
the ultimate..................................55 gallon drum, put block in then submerge with diesel. then seal drum!!
01-09-2007, 08:50 PM | #13 |
Re: Engine Storage
That's a hell of an expensive storage, say 40 gallons of diesel at 2.50 a gallon But I guess it'd work,lol.
'72 C/10 SWB 355/ broken TH350 and 3.07s Soon to be 355/700r4 and 3.73s |
01-09-2007, 10:11 PM | #14 |
Re: Engine Storage
Expensive?? Yea, no doubt.......................I did read about this over on the Willys Jeep site however, so somebody at some time has actualy done it. Some of the surplus military containers are sealed with O-rings and are set up to purge all of the air out with like Argon or something. That also would be the hot ticket. We do it here where I work with helicopter sub assemblys. Some of these "cans", they call them, are big enough to time capsule a Volkswagen!!!!!
