01-09-2007, 01:17 PM | #1 |
Location of oil pressure port on block
I haven't been able to find the answer to this via searches - but where is the port on the engine block for the mechanical oil pressure gauge? Can someone provide a picture? Thanks!
01-09-2007, 01:28 PM | #2 |
TOTY 2006
Re: Location of oil pressure port on block
If it is a chevy V8, it is on the driver side rear of the block, next to where the distributer goes in...
01-09-2007, 01:29 PM | #3 |
What year block? On the early blocks with mechanical guage it's behind the distributer.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
01-09-2007, 01:42 PM | #4 |
Parts and more parts
Just about all of the GM blocks has the port on the top of the motor by the distributor. Some also had a port (usually plugged) just above the oil filter on the side of the block. If you are going to hook up the pressure sending unit, you would want the top connection, so that you have the point furthest away from the oil filter.
01-09-2007, 01:44 PM | #5 |
I wasn't sure about late model blocks, sorry if I was vague
01-09-2007, 02:05 PM | #6 |
Details of truck - 1972 C10, 350V8. It has an Edelbrock intake. There is a port near the distributor with a sending unit in it already, but it looks like a water temperature unit.
01-09-2007, 02:28 PM | #7 |
01-09-2007, 02:34 PM | #8 |
Sofa King. We, Todd, Ed.
Sounds like you may have already figured it out, but here's a couple pix anyway. If you have a sending unit that looks similar to this, it's for an electric oil gauge. Just ditch it if you dont need it. The mechanical gauge fittings and oil line still go in the same hole on the block under the distrubutor.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
01-09-2007, 02:43 PM | #9 | |
Chevy truck addict
Why ditch the electronic one?? I dont like having an oil line in the cab.... |
01-09-2007, 02:57 PM | #10 |
I agree, IMO an electric oil gauge is preferable to a mechanical.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon Last edited by johnnywagon; 01-09-2007 at 02:58 PM. |
01-09-2007, 04:22 PM | #11 |
How about a vortec engine, say a 98 model, is the oil pressure port going to be the same as the older engines?
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
01-09-2007, 06:26 PM | #12 |
Thanks for the info.
