Old 01-09-2007, 09:07 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need some quadrajet help...
Can anyone tell me what this little vaccum looking thing is for and do I need to run a vaccum line to it??? Any help would be great.... btw I have not ran this carb before..... Just need some help before I fire it up..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-09-2007, 09:39 PM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: Need some quadrajet help...
Lance, What is the carb number. If that is on the right side of the carb on the forward end it is probably the vacuum break assembly (choke pull-off). It is hard to see from the pictures...but maybe that is my computer screen.
On further review...I reserve judgement as to it's EXACT method of function during the start or run cycle...LOL!
Hook it up to a vacuum line for certain. The spec. on it should be 10-12 inches of vaccum will hold the choke open...if it leaks down it will need to be replaced.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-09-2007, 09:46 PM   #3
Boog
laying low
Boog's Avatar
No, it's not just your puter screen. We've got a serious blurrrrrrrrr goin on here.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-09-2007, 10:05 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
Still have not figured out the new camera..... I can get the carb # wensday as the truck is not at my house right now...
MEMBER #6377
Project "7DEUCE"
Old 01-09-2007, 10:06 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
I dont run a choke on this truck,was wondering if it had something to do with the secondaries..
MEMBER #6377
Project "7DEUCE"
Old 01-09-2007, 10:13 PM   #6
Boog
laying low
Boog's Avatar
Very well could be. Is there a vacumn port at the rear of the carb the right size for a hose to attach this vacumn pod? Seems like my old 85s had this on them.
Boog
primer is finer
Old 01-09-2007, 10:42 PM   #7
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Its on the passenger side right? If so, it is the secondaries. Vacuum line goes up to one of the ports on the front I think. Can't remember now where mine plugged in...
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 01-09-2007, 11:39 PM   #8
FarmTruk
In Memoriam...
FarmTruk's Avatar
I know diddly squat about Q-jets, but heres a link to Q-jet manual scanned on-line. The pic below was copied from there. Good luck...
Linky...http://www.tocmp.com/manuals/Carbs/R...QJet/index.htm
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-11-2007, 09:03 PM   #9
cooters
the vacuum piece is a secondary air valve damper which will not allow the secondary air door to open under regular driving which would cause it to bog. Also slows the opening of the valve when you hit the throttle hard to prevent bog. I love these carbs
cooters is offline   Reply With Quote
Old 01-11-2007, 09:12 PM   #10
rage'nrat638
rage'nrat638's Avatar
you got it brother..should hook up right the in the rear if the carb.
if thats on a 67-72 truck that looks like a newer vintage carb. heres a few pictures of the one i converted to electric choke
the last picture shows it hooked up new to the power brake vacuum fitting in the rear
rage'nrat638 is offline   Reply With Quote
