Old 01-09-2007, 09:23 PM   #1
RVFR
New Member
502bb
Was curious, has anyone here done the 502 swap? if so whats your thoughts on it? was it worth it? anything you would have done different? just pondering the idea vs rebuild what I have.
RVFR is offline   Reply With Quote
Old 01-09-2007, 10:32 PM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: 502bb
Someone on the board that actually lives in your neighborhood has done it. I can't remember who it was though. He got his from Sallee and had some problems, but I think he got them all worked out.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-09-2007, 10:40 PM   #3
brak
brak's Avatar
Re: 502bb
Longhorn Man is running a caddy 500.
I used to have a 1970 Cadillac Deville, with that motor, and it was awesome. I should've pulled the motor when i sold the car
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 01-09-2007, 10:49 PM   #4
FarmTruk
In Memoriam...
FarmTruk's Avatar
Re: 502bb
RVFR...I don't remember the thread, but a board member put one into a 'burb build-up. I think 502RJ is an EXCELLENT choice for motor-vation.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-10-2007, 04:11 PM   #5
Bob Moore
Re: 502bb
A 502 is going in my "67 GMC" shorty. I don't expect any problems different from anyother BB. If you want to look "original" be prepared to spend some $$$$ as short waterpump brackets are expensive. My 67 C20 with 454 has the long pump and clearance to the radiator/fan is tight.
Holler if you have specific questions.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-10-2007, 04:34 PM   #6
RVFR
New Member
Re: 502bb
Now this is what I'm talking about. Nice, wonder thou if it's worth the wiring hassle for the FI? Hmmm
Funny was at the Chev garage yesterday and what is in the shop, ha a 69 camero with a fresh new just out of the crate 572 in it, the owner of the car was letting the chev garage do the install can we say $$$$$$ still 600HPs on stock exhaust manifolds too. ooooeeeee ****, wheres the camera when you need it..
Old 01-10-2007, 05:15 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 502bb
RVFR,I wouldn't sweat the wiring.From all the descriptions I've read the FI for the "Ram Jet" engines is plug and play.You just need a power wire and the rest is a standard motor swap.I haven't done one but from all the literature I've seen it seems like it would be easier than dialing in an ignition/Carb set-up.Try searching www.scogginsdickeyperformance.com or some other GM performance dealer.You might also try GM performance parts.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-10-2007, 05:34 PM   #8
71chevylowrider
71chevylowrider's Avatar
Re: 502bb
There's a guy on this board with I think, a beautiful black 72 cheyenne with a 502 in it.
71chevylowrider is offline   Reply With Quote
Old 01-10-2007, 05:43 PM   #9
71chevylowrider
Re: 502bb
The guy with the 502 is jhow66 & here's a link that shows big block trucks his is about halfway down the page it's a bada$$ black truck!
http://67-72chevytrucks.com/vboard/s...d.php?t=216339
Old 01-10-2007, 06:01 PM   #10
FarmTruk
In Memoriam...
FarmTruk's Avatar
Re: 502bb
One thing I've heard about the "plug & play" aspect of the FI is...the motor will run in "open loop", ie: no "talkback" from emissions sensors to the FI (or is that "closed loop" ). This could lead to a richer than ideal stachiometric ratio (air/fuel ratio), neccesating more frequent oil changes and greater greenhouse gas pollution. But, if that was a concern, you'd be driving a Toyota Prius, not a BBC !
Now, that being said, there is another board member (gosh...I'm new here and can't remember everyone's name and links) who installed a 350RJ and even hooked up cat converters and O2 sensors to enable the FI to operate in "closed loop" Better fuel mileage, lower emmisions. I can't remember his name, but I applaud his efforts at updating to 21st century technology.
Still, if I had a 502RJ sitting around, I wouldn't worry myself too much about the "open vs. closed" loop issues.
FarmTruk Pics Here
Old 01-10-2007, 06:14 PM   #11
71chevylowrider
Re: 502bb
I think this might be the guy & here's a post on his truck with the 350RJ
http://67-72chevytrucks.com/vboard/s...d.php?t=187680
Old 01-10-2007, 08:47 PM   #12
dwaite72lnghrn
Re: 502bb
I put the HT502 in my truck. with the OEM water pump and pulleys fit fine. I then put the Serpentine setup on and it is TOO close for stock fan and shroud. The ZZ502 or RJ502 would fit the same. The early RamJet502 was just fuel and power, later Ramjet 502 needs +12v and O2 sensor. You also need the high pressure fuel pump for it.
The OEM wireharness for the BBC works with the HT/ZZ engines.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
