Old 01-09-2007, 10:41 PM   #1
19GMC63
19GMC63's Avatar
Granny Low 4spd. Identification
Hey guys, I was wondering if someone could help me identify the manufacturer of the 4spd. in my GMC. I know its not the original tranny, because there still is a column shifter on the steering column. (unless column isn't original)
All I can tell you is reverse is to the right on the shift pattern. I also see two electrical connection thingys towards the front of the tranny. Have no idea what that is. (reverse lights?) There are a few casting numbers, kinda hard to see, I also see a "GM" stamp.
thanks for your help.
19GMC63 is offline   Reply With Quote
Old 01-10-2007, 02:59 AM   #2
rwgregory
Re: Granny Low 4spd. Identification
It sounds like you have a 1966 or newer New Process 435 4-speed trans. Yes that 2 wire thingie is a hookup for reverse lights.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 01-11-2007, 12:32 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
This page should help.
http://www.novak-adapt.com/knowledge...on_gateway.htm
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-11-2007, 12:55 AM   #4
19GMC63
19GMC63's Avatar
cool, thanks for the link.
Judging from the pics and info, i'm positive this one is a SM-465.
So how to I make use of that reverse light switch? Just run a power wire, then run the other to the backup light?
Old 01-11-2007, 06:38 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
Yep. Tap off the fused ignition, so you don't run the battery down.
Fred
