Old 01-09-2007, 11:59 PM   #1
68burb
68 burban in need of patch panels
I need to replace the piece of the rocker area but it isn't the lower outer section like most. mine is just the "rib" that holds the door seal. do I need to buy the whole rocker piece to get it or is the inner rocker piece gonna be enough to get something mounted to hold it. also i do need the lower kick panel area piece as well.
who makes the best fitting pieces, cost doesn't matter.
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's
1995 K2500 Burb as daily driver 350 with 193K miles
1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse
68burb is offline   Reply With Quote
Old 01-10-2007, 11:20 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 68 burban in need of patch panels
Take some pics of what you need. I may have a few pieces left over from mine that would work.
Hart_Rod is offline   Reply With Quote
Old 01-10-2007, 10:26 PM   #3
68burb
http://67-72chevytrucks.com/vboard/s...=200387&page=3
post 67. it's the rib that runs down the door sill that i'm in need of. i was just gonna order a rocker panel and cut the sill portion off.
Old 01-10-2007, 11:22 PM   #4
Hart_Rod
Hart_Rod's Avatar
Thats probably the best way to go. That way if you end up replacing the whole rocker you'll have it anyway.
