Old 01-10-2007, 01:37 AM   #1
Morgsie
Mystery gas tank noise
Hey guys, I got a buddy who recently bought a '67 GMC 920. The truck runs alright, however there is a noise which is bugging the hell out of him. I believe this mystery noise is comming from the gas tank. Basically when you turn corners (usually the faster you're going and the tighter the corner the more audible the sound) you can hear something go from one end of the cab to the other. I've only heard the noise when the tank is near empty, but he says it does it even when full. Now I have a couple of questions:
1. Is there a baffel in the tank. If so, could it brake off and be causing this noise.
2. The gas gauge does work, which would lead me to believe that float has not broken off and floating around.
3. Has any one had or heard of this problem before.
Another buddy of mine owned an '88 GMC 1/2 ton which didn't have a working fuel gauge didn't work. He thought it was the actual gauge, so I tested it with a known good sending unit and the gauge worked fine. We dropped the tank to find that the baffel had separated from the tank and in the process took the float with it, so that's why I'm asking about the baffel. I personally think someone dropped a bolt or something into the tank, but who knows. Just wanted some input before we tear it out this weekend to see if there really is something in that damned tank!
Thanks,
morgsie
Morgsie is offline   Reply With Quote
Old 01-10-2007, 02:15 AM   #2
chopper103in
chopper103in's Avatar
Re: Mystery gas tank noise
someone could of changed the sending unit before ------maybe an old float bouncing around
i know i have one loose in my tank
chopper103in is offline   Reply With Quote
Old 01-10-2007, 02:18 AM   #3
ClassicRedneck05
ClassicRedneck05's Avatar
that or old build up it the truck sat a while that or as well as someone stickin things down in it that could have been broken off or droped into it
ClassicRedneck05 is offline   Reply With Quote
Old 01-10-2007, 04:51 AM   #4
Mudder
Mudder's Avatar
Take the tank out and look at the condition of the floor under and behind the tank.
Mudder is offline   Reply With Quote
Old 01-10-2007, 06:34 AM   #5
72armyswbtruck
72armyswbtruck's Avatar
It might just be a hotwheels truck, when my brother took his out and had it treated and cleaned he found a Hotwheels car.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-10-2007, 01:33 PM   #6
Mudder
Mudder's Avatar
It's most likely the floor has rusted along the back edge of the floor and the sound you hear is coming from inside the tank of the back wall of the truck and floor moving aginst each other. I dealt with the same thing several years ago with another cab after removing the tank probably 3 times to see what was in it.
Old 01-10-2007, 02:16 PM   #7
Morgsie
I won't know until I check it. I wouldn't think the floor is rusted out, the rest of the truck is in surprisingly good shape. Cancer just starting to eat through on the drivers rocker. That doesn't mean that there isn't any other rust, but I'm still leaning towards that there is something in the tank. When it moves around it sounds like it's tumbling. Again, I won't know until I check it. I'll also make sure to post whatever I find. Thanks again guys.
-morgsie
PS: I guess I should ask, the tank looks fairly easy to take out. Bolts along the top, disconnect the fuel line and sending unit wire. Any other surprises to look forward to?
Old 01-10-2007, 04:18 PM   #8
chevy71super
Mine did the exact same thing. When gas tank was close to empty something was rattling around when you went around a corner. When I rebuilt the truck and removed the gas tank and tipped it upside down out came the culprit . . . the center of a locking gas cap. Apparently someone punched it out at one time and let if fall into the tank.
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 01-10-2007, 04:24 PM   #9
69lnghrn
whats a wrench
69lnghrn's Avatar
my truck makes the same noise and its all my fault!!! i lost my gas cap key while working far from home. so i decided to take apart my gas cap i preceded by poping off the metal flange that holds the center core and there she went.. plop ,right into the tank ! oops
i went to auto zone bought a crappy cap put gas in it and im still driving it like that . i need to replace my tank anyways it has a hole on the top of it so i can never top it off.
69lnghrn is offline   Reply With Quote
Old 01-10-2007, 04:47 PM   #10
Critter
Future TOTM Winner
Critter's Avatar
You might get lucky with a long magnet. Could be worth a try before you pull the tank. Just cut a few doughnuts to the right so that everything will fly over to the left under the cap area.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-10-2007, 06:16 PM   #11
toms68cst
toms68cst's Avatar
Forgive me for stating the obvious but you can hear the gas itself sloshing around if the gas tank is about 1/2-3/4 full. Sometimes the gas in my truck really slaps the sides of the tank. If it's someone new to our trucks it may be unexpected.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 01-10-2007, 07:25 PM   #12
Boise69
The Hammer Man
Boise69's Avatar
I get a boom sometimes in my tank, scares the hell out of me. But then again just having that tank in the cab has me a bit nervous. But yea i get this.... boooom.... sometimes and i just figured its the gas moving around.
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 01-10-2007, 09:37 PM   #13
John Fabris
TOTY 2006
John Fabris's Avatar
I am willing to bet that it is a broken gas nozzle from a gas pump... I have pulled several tanks and found gas nozzles, one tank had three of them in there!!!
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 01-10-2007, 10:17 PM   #14
FarmTruk
In Memoriam...
FarmTruk's Avatar
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-10-2007, 10:34 PM   #15
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: Mystery gas tank noise
I vote for pieces of an old locking cap being the source of the noise
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 01-11-2007, 02:56 AM   #16
7T2 K10
7T2 K10's Avatar
Mine makes the same noise. But havent got around to finding out what it is. Please post up when you find out what it is.
7T2 K10 is offline   Reply With Quote
Old 01-11-2007, 04:23 AM   #17
oldpurple
As others have said, most likely just something in the tank.
Solution: stop going around corners
oldpurple is offline   Reply With Quote
Old 01-13-2007, 09:02 PM   #18
Morgsie
Mystery solved! Looks like chevy71super called it (see photo). Thanks again guys.
Old 01-13-2007, 09:19 PM   #19
rage'nrat638
rage'nrat638's Avatar
hey nice picture...glad you got'er done...
now let's see the rest of the truck
rage'nrat638 is offline   Reply With Quote
Old 01-15-2007, 04:31 PM   #20
69lnghrn
whats a wrench
69lnghrn's Avatar
ALRIGHT!!! THANKS FOR KEEPING UP WITH YOUR THREAD NOW I GOTTA GET MY CAP OUTTA MY TANK
Old 01-16-2007, 06:40 AM   #21
Morgsie
It took me a little under 2 hours to do it. I pulled the seat (8 bolts), disconnected the fuel line, sender wire, unbolted the gas tank (10 bolts), pulled the gas tank out, poured remaining gas into a 5 gallon pale, almost filled up the pale. Thought the tank was empty, guess not, haha. The lock didn't fit through the filler neck, I had to grab onto it with a pair of pilers and then with a slot screw driver move the 2 locking tabs and it finally pulled through. Reinstalled everything, ran gas through a coffee filter and refilled the tank. If I were to do it again, I'd just put the seat forward and pull the sending unit out (which wouldn't require pulling out the seat or tank) and then fish around with a magnet, but hindsight is 20/20...
Old 01-16-2007, 10:18 AM   #22
69lnghrn
whats a wrench
69lnghrn's Avatar
cool, im going to hop on it today !! no work for me. ill post my cap later today! thanks for the info Morgsie !!
Old 01-16-2007, 02:39 PM   #23
ghetto_superman
ghetto_superman's Avatar
good thing about removing things from gas tank= theyre always nice and clean when they come out!
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 01-16-2007, 09:23 PM   #24
69lnghrn
whats a wrench
69lnghrn's Avatar
<a href="http://photobucket.com/" target="_blank"><img src="http://i147.photobucket.com/albums/r316/lazquilon/DSCI0005-1.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a> okay guys i think it took me longer to figure out how to post a damn picture, then it took to get my little buddy out the gas tank its been with me for awhile but its time for him to go in da trash !!
Old 01-16-2007, 09:24 PM   #25
69lnghrn
whats a wrench
69lnghrn's Avatar
ok i still dont know how to post stand by i am almost there
