Old 01-10-2007, 01:53 AM   #1
oompaloompasc3
help... lowering question.
hey guys i have a 69 swb c10. it has a leaf spring rear over the axle. i was wondering if anyone might know where i can get leaf springs that will lower it. its a 1/2 ton by the way. if anyone knows i would love to try and convert it to a trailing arm suspension but i dont know how hard that it. any info would be great.
oompaloompasc3 is offline   Reply With Quote
Old 01-10-2007, 07:46 AM   #2
pkj
Re: help... lowering question.
one thing i do on the newer trucks i lower is have the leaf springs re-arched. i can get the amount of drop i want cheap. i have also had them re-arched and a spring added on certain ones that needed to be dropped yet be able to haul. just a thought.
pkj is offline   Reply With Quote
Old 01-10-2007, 09:06 AM   #3
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
you can rearch springs to lower it..i knew you could do that to rase them,,but not to lower them..who does this kinda work,,and about how much to do it..
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 01-10-2007, 01:56 PM   #4
72MARIO
72MARIO's Avatar
http://www.calvertracing.com/app/app.htm
They sell a flip kit (6" drop) as well as a traction bar set up. Alll the drag racers are running it. I am going to order a set in the next couple of weeks.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-10-2007, 02:08 PM   #5
pharcyde05
pharcyde05's Avatar
how much are you looking to lower it that are quite a few dierant ways to achive what you are looking for some have ben mentiond above you can also change shakel lenth and either replace front hanger with aftermarket or relocate you factory one
you can get you springs done at some 4x4 shops or at exaust shops whoever is close by that uses a tubeing bender
pharcyde05 is offline   Reply With Quote
Old 01-10-2007, 03:48 PM   #6
oompaloompasc3
im looking for a couple inches maybe like 3 or 5 i would love to go with trailing arms and springs but does anyone know how to go about doing that.
Old 01-10-2007, 04:16 PM   #7
pharcyde05
pharcyde05's Avatar
i have seen a few threads on hear where guys have done that all you need is the parts and the right mesurments for location of crossmember
some guys get new rear end that has diag pads and some cut old strait ones off and weld on new diag pads for the arms
