Old 08-23-2002, 09:38 PM   #1
Cheyenne Super
Bed solutions
I think i have come up with an alternative to wood beds when the sheet metal bed is too beat up or is rusted through.
I talked to a local plastics fab shop and they think that 3/4" abs (based on thickness for wood bed) would support the same load due to the cross member spacing. Especially if ribs, simialr to stock, were cut and attached with abs glue to ad stiffness.
He is supposed to call me back and let me know the exact specs.
What do you think?
1971 Cheyenne Super
Soon to be converted to '68 front clip.
Efland, NC
Cheyenne Super is offline   Reply With Quote
Old 08-23-2002, 09:44 PM   #2
Southpa
Southpa's Avatar
I often thought about doing the same thing. What kind of $$$ are we talking here? in comparison to replacement with wood planks?
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 08-23-2002, 09:48 PM   #3
smitty62
smitty62's Avatar
Sure would be slick! If you don't mind stuff sliding around?
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 08-23-2002, 09:57 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've thought of clear plexi glass for a rece truck, or a show deal...esp if you have a chrome rear end in it.
I was trying to talk a guy in Tx with a 68 step drag only ride to do this...he had the full chrome rear too...woulda been sweet.
Old 08-23-2002, 10:18 PM   #5
Cheyenne Super
slippery
i thought of that. I would probably spray the bed with a bed liner, or maybe just the plastic part. the only reason i am concerned about the wood is b/c i want to be able to use the bed as a bed without worrying about the wood getting scratched and dented and needing perodic refinishing.
1971 Cheyenne Super
Efland, NC
Old 08-23-2002, 10:24 PM   #6
chevy4ever
chevy4ever's Avatar
A friend of mine and I redid his bed that was just sheet metal layered across the org boards . We got 3/4" ply wood and made the bed in two parts. Real easy only took about 14 hours to do the whole job. Got a bed mat from Pep Boys for $49 for a 73 and it fit like a charm... It looked great, had great support and who cares what you do to ply wood????? The guy with this truck is Quick68c10
email is matthew.solar1984@gmail.com
1980 Malibu Classic 2door(sold) 8-(
2001 Silverado single cab 4.3 V6(stolen and the totalled)
1979 GMC sierra swb stepside 350(sold)
1990 chevy suburban 4x4 350
2001 tahoe 4x4
2001 suburban 4x4
chevy4ever is offline   Reply With Quote
Old 08-23-2002, 10:32 PM   #7
Cheyenne Super
plywood...
... can be damaged if exposed to water for over a period of time. not to be picking at everyones suggestions, i really wish the bed floor was avaliable or at least the halves.
1971 Cheyenne Super
Efland, NC
Old 08-24-2002, 01:52 AM   #8
colohusker
You and me both Cheyenne Super! I remember seeing the 2 halves either in a catalog or a website, but didn't know about the quality. I'll try to find it and send you the info...
Scott
I say it's only money, my wife says it's only a truck....
'71 C10 Deluxe, factory ac, ps, pb, should be done by 2102
Longmont, CO
husker95@hotmail.com
colohusker is offline   Reply With Quote
Old 08-24-2002, 08:34 AM   #9
Huck
Huck's Avatar
Longbed half floors are available but----then you have to contend with all the bed supports. I think they are welded to the bed floor? they you would have to weld the center seam which would not be a fun day. Sometimes just finding a scrap bed with a good complete floor might be better but I have a similar situation so ---I'm not the expert. Pulling a bed, unbolting about 200 rusted bolts, cutting the rear alignment welds----and then replacing with another floor that you had to do the same thing to~~~Ug! Perhaps that will be a winter project. Good thing the sides are salvageable.
Huck is offline   Reply With Quote
Old 08-24-2002, 12:35 PM   #10
dwaite72lnghrn
When the original wood bed went in my truck I redid it in 2X6 and 2X8 pressure treated. The truck was mainly work and I needed a quick bed. I picked up 1/4-20 carraige bolts nuts and washers bolt cutter took care of the original bolts bed was so far gone I broke it out with my hand which allowed me to get the bolt cutters in to clean the old out. When I was finished the bed sat about 1" higher but I don't mind dropping in a couple ton of stone or firewood. The nicest thing about wood beds are things just don't seem to slide as easy in the bed on turns.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 08-24-2002, 03:38 PM   #11
chevy4ever
chevy4ever's Avatar
yeah..with that plywood bed we loaded tons and tons of wieght...we cleared out a shop and had a few blocks, and the rest of the bed was filled in my smaller parts andthe bed didnt have any trouble taking it. I tell ya wood requires more work on them, but they do last if you keep them treated and such, and with a quick plywood job a bedmat makes it look sharp. I think quick68c10 myte have some pics.
2001 tahoe 4x4
2001 suburban 4x4
