Old 01-10-2007, 03:46 PM   #1
Boise69
The Hammer Man
Boise69's Avatar
Sealing the engine
In Feb I start my de-construction effort on my 69. Pulling the cab, the front clip and bed...
I'm going to pull the 350 and trans to have it re-sealed. A local trans shop will do the trans but i'd like to attempt the engine myself.
When the engine is on the stand :
Does anyone have a good link on the procedure of re-sealing the engine or a book suggestion i may purchase or a good ole fashion checklist would be much appreciated.
TIA
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 01-10-2007, 05:07 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Sealing the engine
Define "Resealing the Engine". Are you wanting to rebuild and have the valve guide seals and new piston rings, or are you wanting to just redo the crankshaft seals and the valve covers? How old is the motor and how many miles does it have on it? Where are the leaks associated on it and does it have plenty of power, still? These items helps to decide what you are going to do?
piecesparts is offline   Reply With Quote
Old 01-10-2007, 05:39 PM   #3
Boise69
The Hammer Man
Boise69's Avatar
Good questions. The engine is not that old, The PO obviously did work on it, but it leaks, drips its got grime all over the lower side of it and therefore i'd like to remove the heads and have them inspected for wear, possibly replaced or machined, i'll need to re-seal (gasket) them afterwards. Since having it out of the truck and on a stand, what should i do to it other than cleaning it up, re-painting the block and putting in new gaskets?
1997 MBZ E420
Old 01-10-2007, 05:45 PM   #4
Ole Blue 68
Ole Blue 68's Avatar
If you got leaks on the low end then you should be addressing them too. Having the engine on a stand would be a perfect time for a new one piece oil pan gasket and rear main seal.
Ole Blue 68 is offline   Reply With Quote
Old 01-10-2007, 05:56 PM   #5
Boise69
The Hammer Man
Boise69's Avatar
it burns oil, the compression was good awhile back but i'm going to recheck that, i just want a checklist of everything i should do to the engine now that its on a stand
1997 MBZ E420
Old 01-10-2007, 06:13 PM   #6
Richard H.
Spanked once
Richard H.'s Avatar
Sounds like a money pit in the making to me! Can't really do the rear seal right without removing the crank, and awe heck while it's out I might well have the crank ground and go with the new bearings and on and on...., I have a '59 drof tractor that I only wanted to fix the power steering on in my shop...next thing I knew I had over 1300 dollars just in the engine and I did the build.
Life is good, Richard
Richard H. is offline   Reply With Quote
Old 01-10-2007, 06:45 PM   #7
bobthecop
bobthecop's Avatar
I'd just go ahead and plan on a rebuild, if ur considering new heads, go ahead and do the bottom end too. Then you know what you have.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 01-10-2007, 08:28 PM   #8
bill_in_sd
bill_in_sd's Avatar
If you took the time to pull the motor an transmission out, I would rebuild it now.
No sense messing with trying to pull it out of your beautiful painted front clip later, if something comes up. No way to really know without digging in.
my $.02736 (inflation)
Bill in SD
1971 GMC 1 Ton Custom Camper - I think....
bill_in_sd is offline   Reply With Quote
Old 01-10-2007, 08:36 PM   #9
Boise69
The Hammer Man
Boise69's Avatar
That all makes sense. Thanks for helping me picture it all in my head.
I'm going to take it little by little, avoiding getting too over my head. I guess i just want to clean it up and fix what is making it drip on my floor. I hate seeing oil drips. , it runs well, so i dont want to tear into it unless i find something troubling when i clean it all up.
1997 MBZ E420
